Livorsi 4 5/8" DataTach/Prop Slip Multi Gauge
Livorsi 4 5/8" DataTach/Prop Slip Multi Gauge by Livorsi Marine
Info. & order link:
Livorsi's revolutionary DataTach™ Prop Slip™ Multi-Gauge is a digital gauge that lets you know if your getting the maximum performance out of your boat. This one gauge displays: Compass Heading, Single or Dual Tach readings, Propeller Slip, GPS speed and recall, and an optional Record and Document. The DataTach™ Prop Slip™ has a computer that receives GPS speed and RPM info and caluclates the slip of your boat's properller 5 times per second. A lower prop slip% = better performance.
DATATACH™ PROP SLIP™ MULTI-GAUGE
The Livorsi DataTach™ Prop Slip™ Multi-Gauge is offered exclusively at Livorsi Marine Inc
Large easy to read LCD digits can be seen in direct sunlight
Fits into a Monster GPS cutout
All readings with Recall
Optional Recording Module - see www.propslip.com for analysis results
Available in a Mega or Race rim in 13 brilliant colors to tie into any existing dash
Available for in-dash or portable version
Know your boats most effective drive height, trim angle and propeller size to gain more speed and increase fuel efficiency
Info. & order link:
Very valuable information for sure. The reason it is valuable is because the data is accurate. The more accurate your data the more accurate your dial in work will be. Great Product!
Julie
Julie
tpmarine.com
New Products and Member Discounts
6
06-28-2007 02:14 PM
teaguecustommarine
5
02-28-2007 05:23 PM
Livorsi Marine
0
02-16-2007 05:13 PM
