LISA 50' Nortech
Originally Posted by Bobthebuilder
James, help us out here. What boat runs 132 MPH with 3 X 480's ? I know Reds' V runs in the low to mid 70's with his setup.
Bob
Bob
I believe he misread the post.
Originally Posted by warbird
Bob,
Sorry, just read the first line above...then went and had a margarita and re-read. Must've gotten excited about Red's boat......
I was actually hoping you were right but someday ..... those diesels will push us 80MPH plus and I will sign up for that program.
Bob
Ha, that explains it then !! LOL
Bob
Bob
Jeff
Originally Posted by Jassman
If Hustler can do it, with their 50', Nortech definatly can. Nortechs boat is also 2' longer, and wider, as well as weighs appr. 2500 more pounds. I believe they just need more dialing in time. Im working on a 80 plus mph 4300 with twins. A light layup should get me there. It will be close. Cant wait.
Jeff
JeffA 43' NT with twin diesel running 80MPH would be a great setup. The weight savings with Kevlar will no doubt make a difference. I hope they can do it.
At Sarasota we ran along side of the Hustler for a while on the way to lunch. They were running steady in the low 70's. But then I had to go back to work and left them.
Looked good tho and not out of place at all.
I ran with Red from Miami to KW in November 05'. Nice guy. Daughter was sweet as well. I had never met him before that day but my original ride to KW (50 ft NT Warrior) decided not to run. Since I had just hopped a flight down to Miami at the last minute for the poker run, Red was kind enough to let me tag along. What a smooth ride. While not exactly the top end that Warrior has, it was a great ride. Like a Rolls Phantom on the water.
Bob
Bob
Thanks Guys
....Jeff
Hello Jeff,
Originally Posted by fordsofflease
I agree thats why I'm building a 4300 with tripple 650 efi nor tech motors out of kevlar maybee 100 mph?????
When will yours be done, thanks Jeff
Jeff your boat was next to mine in rigging great long range low maintience set up.Unfortunately I'm a little old school but I built my first 43 2 years ago with tripple 625's with xrs and the boat ran 90 mph in any sea wheather or weight conditions they built a trip 525 xr heavy lay up after mine with slightly higher x dimension that runs 92 mph.This boat is the first kevlar 43 but we put imco extreme drives with boxes and word has it the 650 efi's will dyno at 660 hp.so the goal was 100mph without blowers x dimension is aprox 4 inches higher keep in mind 2 years ago there were no 5 blade props to break this monster out of the hole now we have 6 blade herrings.hope for 100 mph but might do alittle better.Due date is july 16th first poker run is fpc bahamas july 20th lets see what happens.By the way how do you like your rig?
