36 Cat Mufflers???? >
36 Cat Mufflers????
36 Cat Mufflers????
Old 06-03-2006 | 02:49 PM
Chuck's Avatar
Default 36 Cat Mufflers????
I had some CMI mufflers from my Spectre that I had CMI modify to fit the tails on my Nor-Tech. They caused some reversion on the starboard motor. What are you guys running for mufflers, and what has been the results?? I plan on doing the under water exhaust conversion this fall, but I don't want to lose 1/3 of my season doing it now. Any suggestions would be greatly appreciated.
Chuck is offline
Old 06-04-2006 | 08:18 AM
Ratickle's Avatar
Default Re: 36 Cat Mufflers????
Were these the new Sound Elimination System CMI's? If so what were you running before and what is the exhaust size and cam overlap? These are one of the mufflers I am considering for the Black Thunder.
Ratickle is offline
Old 06-04-2006 | 06:02 PM
Chuck's Avatar
No they weren't the new CMI's. I had no mufflers before I tried these. Sorry I can't be of more help.
Chuck is offline
Old 06-04-2006 | 06:42 PM
drypipetiger's Avatar
When I saw your rig the other day at Vermont Home and Marine I thought about this guys rig because they appear similar. I wonder if he's had any reversion issues?
drypipetiger is offline
Old 06-04-2006 | 07:15 PM
Sean H's Avatar
A to Z
3600cats run nearly completey dry through the muffler, some water, but not enough to worry about reversion... his stellings drop the water out the bottom of the tip before the muffler...
and he still isnt very quiet...
Sean H is offline
Old 06-04-2006 | 09:01 PM
WeaponX's Avatar
My boat is quiet as a church mouse.
I'll be trying more water tomorrow. No reversion so far.
WeaponX is offline
Old 06-05-2006 | 08:02 PM
Chuck's Avatar
Do you think I have a diffrent problem Sean?? The exhaust tips are the only change from last year. Got some clear water on a closed cooling boat. Thanks.
Chuck is offline
Old 06-05-2006 | 10:18 PM
Sean H's Avatar
A to Z
modifications are in process....
Attached Thumbnails 36 Cat Mufflers????-dscf1336.jpg   36 Cat Mufflers????-dscf1396.jpg   36 Cat Mufflers????-dscf1398.jpg
Sean H is offline
Old 06-06-2006 | 04:47 PM
WeaponX's Avatar
@#@#%$* water patrol. You know I love them.
WeaponX is offline
Lofty
Swap Shop
4
07-31-2008 10:25 AM
BARCOASTAL
06-25-2006 04:31 PM
cosmic12
04-25-2006 07:33 PM
Tim G.
12-15-2003 07:25 PM
88 MACH 1
13
07-16-2003 12:54 PM
