Water pooling in the cabin of my 43V.... >
Old 08-20-2012 | 02:43 PM
Default Water pooling in the cabin of my 43V....
So I have managed (with the help of some great boating friends) to iron out almost all of the initial bugs that came with buying a boat with no documentation of any kind, but last night we figured out that the water pooling around the bottom step in the cabin is coming from the shower drain.
Is there a solution for this? I can't find an access hatch anywhere that might house a pump, and when I dump water down the shower drain I can't track it to any outlet other than where it is pooling at the bottom step between the head and the sink.
As usual, any help or suggestions is greatly appreciated.
5 days into Nor-Tech ownership and you still can't wipe the smile off of my face. What a fantastic hull and overall great boat.
-Greg
Team Crown is offline
Old 08-20-2012 | 02:52 PM
bill63's Avatar
Fast Priorty II Nor-Tech
Did you call Nor-tech ? Ask for that Sobo dude.....
bill63 is offline
Old 08-20-2012 | 07:14 PM
rv
In the cabinet to the right at the cabin entry, the bottom floor has a panel that lifts out. Look for screws in carpet.
rv is offline
Old 08-20-2012 | 07:25 PM
wgg
Your shower sump pump is not working. Basically an auto bilge pump inside a small square box(sump) w/a clear lid . As water flows out of shower drain the box fills up. pump has to pump it out since it is too low to drain overboard. Should cycle automatically when water is running. Might have a stuck float or clogged discharge hose
wgg is offline
Old 08-20-2012 | 07:39 PM
OldSchool's Avatar
+100
He's been known to be quite helpful!!
OldSchool is offline
Old 08-21-2012 | 06:49 AM
thats what it sounds like to me as well... on my previosly owned 400SS it was under the mattress of the cabin, dont know where it would be on a 43V but I'm sure this Sobo guy may know!!!
Spicy is offline
Old 08-24-2012 | 07:02 AM
Found it. And the pump was burned out.
New pump installed and everything is good.
Thanks for your help.
-Greg
Old 08-26-2012 | 04:40 PM
rv
You are welcome, glad it helped.
Rick
rv is offline
