Renderings ... >
Renderings ...
Renderings ...
Old 04-18-2025 | 01:22 PM
  #181
Originally Posted by Rookie
Been there done that.
I've been bathing my threads in ARP lube when putting them together. Haven't had a failure since. (crossed fingers...)
I`ve learned to do that too. .. didn`t help this time around
ICDEDPPL is online now
Old 04-18-2025 | 01:24 PM
  #182
[QUOTE=LakeBoat4;4924489]
Originally Posted by ICDEDPPL
$250 down the drain.
AN firrings are stupid expensive now , as is the hose
I had issues with Stainless on Stainless fitting. Same on same metals like to gull.
Sign of the times Dan. Everything is stupid expensive these days, especially high performance or specialty products. I feel your Pain. Got my second engine on the Dyno warming it up for a few pulls and the MEFI lost spark. Swapped in the ECM from the other engine that ran Great. Tune was totally off for some reason and down 10% in HP and TQ. So Try finding a MEFI 4B ECM these days. Prices for a used one start at 3X what a new one used to cost if one can be found with no guarantee it works. Found out there is major leak down in two cylinders one in each head. Knew the Heads on the engines would not go back on once off again and just ordered 2 new sets of bare AFR's. 6-8 week delivery, will turn out to be longer for sure. Went with the biggest 24 degree heads as the first engine started to lay over at 1345 hp.
Great looking switches when finished the boat will be a show piece for sure.
I have 2 MEFI 4B`s I`ve been saving .. if you get in a real pickle let me know .. I might sell one.
Old 04-18-2025 | 07:13 PM
  #183
[QUOTE=ICDEDPPL;4924496]
PM me on the info. I'm looking
LakeBoat4 is offline
Old 04-20-2025 | 07:56 PM
  #184
The bluetooth switches are pretty cool .
No wires.
Now I have Tab control on the steering wheel.
Old 04-20-2025 | 09:36 PM
  #185
Try anti-seize on the AN fittings. Used to prevent galling on similar metal threads and corrosion on dissimilar metal.
zfrilly is offline
Old 04-21-2025 | 07:57 AM
  #186
Be interested on how those bluetooth switches work, if there is any delay. They look good.
Looks like you just have trim both, rather than individual?
Do you have DMC drive sync on just the drives or or both drive and tab?
Wildman_grafix is offline
Old 04-21-2025 | 03:28 PM
  #187
No delay at all. Works up tp 30' away.
trim both at the same time .. I still have individual switches.
Old 04-22-2025 | 09:53 AM
  #188
Wally's Avatar
Were doomed!
Is that steering wheel switch hard wired or on batteries? Just curious since i dont see anything...very cool idea though
-Wally
Wally is offline
Old 04-26-2025 | 11:16 PM
  #189
Wally, I`m sure there is a battery in there.. blootooth as mentioned.
Old 05-15-2025 | 06:26 PM
  #190
How are the new engines coming along? Will she be ready for Memorial Day Weekend?
SecondWind is offline
