Go Back  Offshoreonly.com > Owners Forum > Nordic
Prop for 700-800hp Rage >
Old 11-19-2009 | 11:42 AM
CB-BLR's Avatar
Chris
Bobl,
My boat usually runs 15%-16% slip using Bravo's & 12%-13% using P5x's.
I believe they are using Bravo props.
The faster the boat is going with the outdrive depth being the same ... the less boat and outdrive/prop there is in the water... therefore increased slip.
The 130mph+ Howard Bullett ran slip numbers in the 18%-20% range at top speed.
I'm beginning to value slip numbers less and less, and look at overall speed and boat handling more and more.
Who the heck cares what the slip percentage is if it is indeed the fastest prop for your boat, and speed is what you are after.
Chris
CB-BLR is offline
Old 11-20-2009 | 03:53 PM
Originally Posted by CB-BLR
Bobl,
Chris
That was my thought. As mph goes up, boat gets higher, lighter, more prop out of the water & increased slip. Spring I'll try 3500 rpm vs 5500 rpm & compare slip % to test the theory.
90mphRAGE is offline
Old 11-21-2009 | 04:04 AM
Wow! Got a few people shook up. Was not my intent. Time I think to look at a few quotes. Perhaps a bit of sober thought.
xcpilot is offline
Old 11-21-2009 | 04:07 AM
[QUOTE=CB-BLR;2988040]Somewhere the math is off...
at 29 pitch.. which is what a 30 is stock.. slip is at 6.7%
at 30 pitch .. slip is at a little over 9%
It is hard to believe that a Bravo prop has slip that low ... Hmmm
Anyway... I agree with Steve... demo a Hydromotive 30 P5x. Hydromotive has a demo program. Going up 1 inch in the hydromotives pitch will reduce rpm aproximately 150-170 rpm.
That is my favorite all-around prop.
I regularly spin a labbed 30 p5x at 5600 rpm to 92.8 mph which equals about 12.2% slip
Here's one that's interesting.
xcpilot is offline
Old 11-21-2009 | 04:08 AM
[QUOTE=CB-BLR;2992996]Bobl,
Here's another.
xcpilot is offline
Old 11-21-2009 | 04:13 AM
Originally Posted by bobl
Interesting. I've set up several Rages and they all come out under 14% slip using stock props. A 496 HO usually comes stock with a 26 Bravo 1 prop. With 17% slip that works out to 68 MPH at 5000 RPM. We all know an HO Rage runs low to mid 70's stock. My Rage runs 70 at 5000 RPM (on a scan tool) with a 26" Bravo 1 in hot weather, 72-73 at 4800 with 28Bravo 1 in cool weather. Another Rage I set up ran 80 with a 26" Bravo 1 at 5600 RPM (13% slip), It ran upper 90's after a blower addition with stock 30" at 5800-5900 RPM(13% slip). So, I'm a bit confused with you guys seeing so much slip with a Rage. Of course once you start labbing and modifying props all bets are off on calculating slip.
Here's another.
xcpilot is offline
Old 11-21-2009 | 04:25 AM
Little bit of math. 5500 rpm on a 30 pitch equals 90.6 mph with Bob's 13% slip. This does NOT include anything for cupping-or anything else! Of course my slip would be higher than a 28' much heavier Heat with a shorter drive (12%). Still trying to figure out why I am a liar and no one questions how some get to 93mph with 28 footers that are 10mph slower than 25's.
xcpilot is offline
Old 11-21-2009 | 04:40 AM
Last day on the lake I went back to the prop shop and got the 31 P5X five blade Hydromotive to re test. It worked very well and I bought it that day. I was able to spin it 5300 rpms on glass water and the acceleration was pretty good. Thinking my slip number should be down 3% at least with the 5 blade (to like 9%) compared to the Bravo4 according to CB so my speed should be pretty good. I'll let him come up with some math to keep my speed down to maybe 89. Gotta be a way for a 25 with a deeper drive to have a bigger slip than a 28 with a shorter drive.
xcpilot is offline
Old 11-21-2009 | 10:37 AM
Any one that knows me, knows I'm a stickler(sp) for data and accuracy. I make my living doing this. One thing I've learned from talking with all these folks around the country. Weather and water conditions make huge differences. So, trying to compare Chris's, Steve's and my numbers doesn't always work. I've run on Lake Cumberland (where Steve boats a lot) and seen speeds 3-4 MPH faster than I ever saw at my home lake.
I've set up and run quite a few Rage's and Heats. I know those boats very well. You are correct that you cannot compare the 2 boats. The Rage is about 8 mph faster than the Heat and runs much less prop slip with all else being equal. Just my 2 cents worth.
I've tried my best to show that your numbers are indeed mathematically possible. However would you please clarify if that speed is on GPS or not. With the HP you're running, 93 is an exceptional speed based on my experience. Also, where are you boating and what kind of weather conditions?
I've never run a P5X on a Rage. I'm guessing a 31 at 5300 would still be around 93 +/-. My Heat spun a 29 P5X at 6200 and 95 mph. What did you think about the P5X on the Rage?
Bob
bobl is offline
Old 11-21-2009 | 10:41 AM
Nordicflame's Avatar
Here's an intersting quote...
Lets see a pic
Originally Posted by Nordicflame
Still looking for the answer to the GPS speedo question
Nordicflame is offline
