Go Back  Offshoreonly.com > Boating by Region > Northeast US
This is for 1CE and the Fall River Poker Run >
Old 11-29-2007 | 09:00 PM
marinetrans's Avatar
Originally Posted by mikes280
i guess everyone has a different idea on water pri. my motor makes 1078hp at 6200 i have 4 years on it at 10 lbs of water pri. run 4 or 5 poker runs a year never had a problem. i like to see a lot of water moving through the motor not always a lot of pri.my heads are the 357 afr's 540 inch motor 3.3 whipple. also i was in a gtx with 1075 merc's and they don't run that much pri.
Nice HP brother!! at 6200 rpm your probably making tons of volume and bronze valve guides help out big time.We found,in our cases,under 10-12lbs,made big problems for valves.Average hours were 2 to 3 before turning into shizzle. 20-25 psi is Merc's spec for psi, they sent a service bulletin on this.To be safe we make sure about water psi, under 20 psi we address water pickup issues,over 30 psi we install Merc's water bypass valve.
marinetrans is offline
Old 11-30-2007 | 12:01 AM
1CE
Default Volume
Originally Posted by marinetrans
It probably runs run on the hose,but top end you'll have no volume of water.A transom pickup is a must.I seen dudes hange valves because of not enough volume.Lack of volume seems to leave steam pockets in the motor,mostly in the heads around the exhaust valve guides.You'll need 1" thru hull and water pessure must be 20-25psi at WOT.
Peter, What's up ? ya Merc, likes 20-25 lbs But like u-said volume and flow is of ut-most importance @ higher rpms. see u-this summer J ps u-online ?
1CE is offline
Old 12-01-2007 | 06:55 PM
KNOT-RIGHT's Avatar
Its about time ya renewed your membership
When are you and Dave comming by the dealership
to drink all my beer and do burnouts with all the cars?
KNOT-RIGHT is offline
Old 12-01-2007 | 08:08 PM
Talking
This week we're coming,lock up all the good booze.
Old 12-01-2007 | 08:11 PM
slboatdrinks's Avatar
Hey Pete,
When's the winter chill-out at your new house for all the northeast OSO'ers?
slboatdrinks is offline
Old 12-02-2007 | 09:13 AM
Haven't been online all summer, too much going on. Steve, I'm ready to party and fall off a bar stool.
Old 12-02-2007 | 02:22 PM
Sick Stinger's Avatar
Brotherhood #1
Ill see all of you out on the water
Sick Stinger is offline
Sick Stinger
Poker Runs and Boating Events
4
04-15-2008 12:23 PM
Sick Stinger
Northeast US
19
04-05-2008 10:52 AM
TomR
1
03-31-2007 12:05 AM
fobes
07-15-2002 06:01 PM
DONZI
07-11-2002 05:31 PM
