CT B.S. Thread
Old 02-23-2011 | 01:56 PM
  #341
Originally Posted by 302Sport
yeah you would be 100% correct haha small world
no sh!t...he was telling me you had a powerplay. we'll have to run together this summer. i have been looking for people my age that own boats. we both know they are nearly non existent. good sh!t man.
1MOSES1 is offline
Old 02-23-2011 | 02:08 PM
  #342
Well, not sure you will run "together", but Adam can prolly help you guys dock when you finally arrive Justin! Hahahahahaha.....just kidding, not starting any trouble. Just remembered about Justins new hair cut!
kreed is offline
Old 02-23-2011 | 02:10 PM
  #343
did you forget i have a seat on your boat when its rough out...2's and under we'll be on our boat.
1MOSES1 is offline
Old 02-23-2011 | 02:23 PM
  #344
Hahahahaha, no, I didnt forget! Your in Justin. Adam will prolly be catching our line too!
kreed is offline
Old 02-23-2011 | 02:30 PM
  #345
trying to touch 100 this year if im running light fuel/no people
302Sport is offline
Old 02-23-2011 | 02:32 PM
  #346
SS930's Avatar
Adam,
What did you finally decide to do with the power for this year?
SS930 is offline
Old 02-23-2011 | 02:35 PM
  #347
AIR TIME's Avatar
hey I got a Queston for all, for the winter blues , ok how much fuel will my 572 blown 1071 motor use per hour running 3500 to 4000 rpm. Right now my saber has a new 90gal tank and if I run easy 60 to 70 cruising whats a thought of mpg. I think 40 per hour. the way its set up now it can run 93. if I turn the boost down maybe 89 . but I loose 150hp. boat has a konrad ace with 1350 tranny. Ihope I can make it from fallriver to block and back. I could with gas left over with the ol 24 and 650hp. plus if I meet up with you guys on the conn river and run to LI and back SHOULD BE ALL RIGHT. I may put saddle tanks over the summer or stick a tank in the floor with another 60gals. I would like to race the LI race in the fall. opa races no problem runnin g out there in class 400. well any ideas. Art
AIR TIME is offline
Old 02-23-2011 | 02:50 PM
  #348
Originally Posted by SS930
Adam,
valve jobs, new cams, intakes, carbs, ignition, bigger oil coolers, and going to spin another 600rpm. should gain another 100hp and be making about 625-630. also raised the drives 2 inches.
302Sport is offline
Old 02-23-2011 | 03:28 PM
  #349
SS930's Avatar
Art,
Given your goals, I'd be looking for another tank bro!
What are you running for heads? As I recall, dont you have fairly low compression? If so, did you do anything to raise it since you're staying NA?
SS930 is offline
Old 02-23-2011 | 03:36 PM
  #350
you are going to need all the fuel you can store...we have 113 gallons with small blocks.
1MOSES1 is offline
