OE Shifting
Old 10-11-2007 | 07:48 AM
aviatorg3's Avatar
Default OE Shifting
Just curious if anyone else has had this problem and if you have a solution. 39 OE 1988, two BBC Blower motors, Huber transmissions, and ASD 1600. When I put it into gear it stalls. Need to set approx. 1500 rpm to shift then set idle after it's in gear. Is this normal? What can be done to fix it? Thank you.
aviatorg3 is offline
Old 10-11-2007 | 09:53 AM
The Menace's Avatar
Call Dave Wesseldyk at Wesco. He can hook you up. It will cost a few bucks but it works and is worth every penny.
1 616 622 2250
He installed the system on my 39 OE with 1100's and 40 Skater with 1000's. No stalling.
The Menace is offline
Old 10-11-2007 | 08:05 PM
aviatorg3's Avatar
What did he install and what does it do? Will it work on non EFI engines. I don't have any computers. Just good old Holley carbs. Thanks
Old 10-11-2007 | 09:03 PM
The Menace's Avatar
Will work real well. I have dominators.
A system much like on a car. It squirts a small amount of fuel into the carb when you pass out of neutral into gear. Pretty slick. No maintenance and it works.
Old 10-14-2007 | 11:41 AM
MarkSmith's Avatar
My motors are 600 cu. in. and from Wesco Racing. They idle at 500-600 rpms in gear. The engines have NEVER died from shifting in gear. In fact, I never touch the throttles at all to park the boat. It is like parking a Searay. Dave has the setup and worth every penny!!!!!!!!!
MarkSmith is offline
Old 10-20-2007 | 03:59 PM
aviatorg3's Avatar
Thanks for the replies. Talked to Dave. He only installs on motors that he builds. He likes to fine tune them so they work perfect. I need to fix my problem without shipping motors. Once again thanks.
Old 11-01-2007 | 04:00 PM
Brad Zastrow's Avatar
Common blower engine problem. Sometimes you can adjust the carbs idle mixture to help. There is a cure that involves a solenoid that will push the throttle linkage a little to prevent the stall. Check with CP Performance, Teague or Ateco can help you out.
Brad Zastrow is offline
Old 11-04-2007 | 07:29 PM
Elite Marine's Avatar
[QUOTE=MarkSmith;2305310]It is like parking a Searay. QUOTE]
Dont you mean Bayliner?
Elite Marine is offline
Old 11-07-2007 | 07:41 AM
MarkSmith's Avatar
If is steers real easy, then that is what I mean.
Old 02-08-2008 | 09:31 AM
copiercat's Avatar
saw this boat in the classifieds and im wondering how does this boat shift and throttle,i dont see any controls and looks like the cabin doors are removed and cut out as well, dual axle trailer ?
Attached Thumbnails OE Shifting-48express-small-.jpg   OE Shifting-48exp-tralr-small-.jpg
copiercat is offline
