My 37 0uterlimits quad step >
Old 07-25-2009 | 10:55 PM
Originally Posted by WildWarrior
Sweet rig ,very impressive #s are you running 1/4" drive spacers?
Can you share your set up?
Drive ratio,prop size ,rpm @ 122mph etc
Thanks!
Glen
y dont have a spacers
0uterlimits is offline
Old 07-27-2009 | 09:55 AM
Originally Posted by 0uterlimits
my prop is 16 1/2 34pitch , ratio 1.35 , RPM 5800-6000 , Run 118-122 MPH
Have you ran bigger dia wheels and if so how does it handle upstairs? Has the bottom had work done since new?
links is offline
Old 07-27-2009 | 11:43 AM
Links are you running 1.35 gears in yours also?
JoeD is offline
Old 07-27-2009 | 04:52 PM
1.50 and 17x33 5 blade. gonna take 1/2" out of dia and add 1/2" spacer. One change at a time and see what happens. Got plenty of power to run in the 120's. May have bottom done this winter.
links is offline
Old 07-27-2009 | 05:19 PM
My boat when seen at the dealer originally did not have drive spacers but when the dealer sent it to Outerlimits for a once over before I picked it up they decided to put 1/2 spacers in, later in my quest for speed I removed them and since sold them,they really did not seem to effect handling either way, I am thinking of this 1.35 gear ratio now.
17x33 4blade
5600 rpms
1.50 gear ratio (currently)
also soon to test 17 X33 5 blades
JoeD is offline
Old 07-27-2009 | 07:05 PM
17x33 4blade
5600 rpms
My motors are good for 6400 and Im not close to that with current set up. I knew when I bought the 5 blades I was going to cut dia to settle ass end down and hope to carry bow better just never did. I really need to spend the time to try setup changes. Props go out this week so I will post results. I get this thing in the 120's without bottom work I will be very suprised.
links is offline
Old 07-27-2009 | 07:29 PM
Good luck with the project,I am lookin for just bit more mid range.
JoeD is offline
Old 07-28-2009 | 12:09 PM
Good luck with the project,I am lookin for a just bit more mid range.
One thing the boat is not lacking is acceleration, The motors literally man handle the hull! Just need to get it to where I can hold it upstairs.
links is offline
Old 07-28-2009 | 02:15 PM
Originally Posted by cowisl
gotta be the purple boat...knotty bouy
huh
Pro1 is offline
Old 07-28-2009 | 03:16 PM
Originally Posted by Pro1
huh
i believe this boat was redone to its current set up...was once known as knotty bouy
cowisl is offline
