Stiletto Water Pick-ups >
Old 08-13-2011 | 02:31 PM
Originally Posted by TCBoss302
37ol,
So you're running 110 MPH with 800's? Do you mind sharing your setup? Stagger/non-stagger, what drives, props etc. Thanks!
Short stagger, 24'' centers , 1.5#6 drysumps with 17.5 x 34'' Merc 5 blade props spinning in at 5800-6000 rpm. This will see 107-110 on most days. This boat has the motors moved forward about 12'' farther than most 37 stagger boats, thats how it was built, flys pretty level.
37ol is offline
Old 08-13-2011 | 02:49 PM
Thats impressive for that hull and that power combo. Are those 800's closer to 900's?
drpete3 is offline
Old 08-13-2011 | 03:28 PM
Old school Teague 8oo's intercooled/carb motors with 220 hrs been that have been running for 7 years, I don't know exactly how much they really put out. I had a friend that ran 117 with merc 900's in the same boat with wet sump drives.
37ol is offline
Old 08-13-2011 | 05:42 PM
Originally Posted by oceanoutlaw
Is any one using the factory installed water pick-up in front of the step on a 37' single step. If so what kind of water quality are you seeing from these pick ups. They seem to be pretty far from the transom and I would think they would pull alot of air. I'm think of eliminating them and going with transom pick-up's while the motors are out of the boat. Any thoughts would be appreciated.
The purpose of the step mounted pickup is that the last good clean water is available there, after the step, its areated, so the water at the transom isn't as "clean". They were set at approx 3/8 down, and tacked so they wouldn't move.
At the transom, you would need at least 1/4 down to get the same water, plus the extra drag.
When a 37 is flyin' proper, its dead level, so the transom is higher than most.
Snakebite A-82 is offline
Old 08-13-2011 | 05:45 PM
a 900 stagger in a 37 will see 121 mph....Bob Christies was the first to see that number, and it was an all glass boat...an epoxy one would gain another 3-5 mph
110 with 800's is the right number
Old 08-14-2011 | 09:31 AM
Is there a driveshaft on rear engine?
MARINE UNLIMITED is offline
Old 08-14-2011 | 10:54 AM
Thanks for the info, gotta love the Stilettos!
TCBoss302 is offline
Old 08-14-2011 | 12:18 PM
Yes, about 12''.
37ol is offline
