Rubix Cube 3 Stage Water Pumps >
Old 05-28-2012 | 12:08 AM
thunderusone's Avatar
Default Rubix Cube 3 Stage Water Pumps
I just rebuilt both of mine including wear plates, orings and impellers. What a pain in the azz. You have to get your mouth right and then turn into a contortionist to get them on and off. At least they are done with all new parts ready to go boating.
Attached Thumbnails Rubix Cube 3 Stage Water Pumps-imag1020.jpg   Rubix Cube 3 Stage Water Pumps-imag1021.jpg
thunderusone is offline
Old 05-28-2012 | 08:40 AM
Are you ever going to put that thing in the water.
Enough 4 Play is offline
Old 05-28-2012 | 10:52 AM
We are out right now!!!! First time this year. We didn't go out last year at all due to my wife's health. Boat is running like a bat outta Hell!!
Old 05-30-2012 | 10:26 AM
I spun the shaft bearing in Jacksonville on mine and its sitting on EB's work bench right now. Going to get them both rebuilt while I'm at it and need a section on housing I think where the bearing took a crap. Check on a new one... Dealer cost is $2200 and rebuilt pumps are like $1300!
gofastlvr is offline
Old 05-30-2012 | 02:18 PM
That BLOWS! I'm sorry to hear that Chad. I go through mine every season myself. I changed everything this time, orings, wear plates, impellers, etc, etc. The hardest thing with mine is getting the one off of my forward motor. It literally touches the forward bulkhead. I changed a Bam dry sump tranny in the Holiday Inn parking lot in Destin two years ago and I swear it was easier than getting that one pump on and off.
Old 07-11-2012 | 08:48 PM
Let me tell you what really blows... Go down to EB's and see my junk that cracked the header and added the exhaust valve to my oil pan via a piston! All we can figure is the header cracked when it got a little hot in Jacksonville and after running it another 8-10 hrs it went boom in KY a couple weeks ago...
Old 07-12-2012 | 09:00 PM
Damn, sorry to hear that the first season out with the new ride. Sweet boat by the way.
SLOWRIDE-388 is offline
Old 07-13-2012 | 08:36 AM
I hate FOD in my oil pan, makes me cranky. I pressure test headers each oil change.
links is offline
Old 07-13-2012 | 08:40 AM
Send me some pix of your boat. [email protected]
links is offline
Old 07-13-2012 | 04:43 PM
We rebuild every season too. They don't like to sit over the winter. Just a lil preventive maintenance. Easier then changing on the dock or while on the water.
See you at the Shootout!
