Props for a Pantera 24 >
Old 07-19-2006 | 07:33 PM
  #51
Pat McPherson's Avatar
Default Re: Props for a Pantera 24
Don't bother spending $$ on a 3 blade, just keep it as a spare. Send your 4 blade to BBlades for some added bow lift.
Get the boat balanced so you can run with out dragging a tab and dump the cast iron exhaust for some good cast aluminum manifolds.
Then Enjoy!
Happy Boating
Patrick
Pat McPherson is offline
Old 07-19-2006 | 08:59 PM
  #52
Ateco's Avatar
Get rid of those stock manifolds.
FYI -
I know a great CMI Distributor!
Kirk
Ateco is offline
Old 06-04-2007 | 10:08 PM
  #53
onesickpantera's Avatar
Update from last year.
#1- I found out the very first Mirage prop I borrowed was labbed at one time. Which would explain why it was slightly faster. Nothing major but the blades were definitely thinner. Good news is I ended up buying the prop.
#2- I bought a non-labbed 26 Bravo and absolutely hated it in the slop. Threw the boat all over the place. Thought about having it labbed but then I risk the chance of having a $700 prop that might not work. So I decided against it.
I have a little more power this year and I am running 76 with a light load with the Mirage and running over 74 loaded up. But, the cruise on this prop sucks. Most of the time I don't care but I do go on some long runs a few times a year. Cornering isn't great either.
I'm planning on trying a Rev 4 prop. I am hoping the smaller diameter won't throw the boat around as much and having more rake will carry the bow better.
I'll post results if/when they happen.
onesickpantera is offline
Old 06-05-2007 | 09:50 AM
  #54
CHAOS REIGNS's Avatar
i have just shy of 600 hp -- TRS and am running a labbed and turned down mirage 25 (turned down to a 24). at WOT i'm at about 5100 rpms and am seeing about 78 on the speedo. I'm actually looking for a 23 to get me up to 5250 rpms and maybe gain a little more MPH.
i drag a little port tab and the boat runs very smooth and flys great -- i've had many compliments on how smooth it is.
CHAOS REIGNS is offline
Old 06-05-2007 | 09:59 AM
  #55
Stormrider's Avatar
JC Performance Engines
chaos, a konrad w/ a shorty would be slick!
probably gain 5mph.
Stormrider is offline
Old 06-05-2007 | 11:24 AM
  #56
Well I have a Revolution4 25 pitch on the way. Should be here Thurday at the latest. Weather permitting I'll be testing this weekend and posting results.
Old 06-05-2007 | 12:30 PM
  #57
i'd love a konrad -- just can't spend the cash (no real sense to right now since mine is working great).
i am thinking about selling and moving up. i've put so much money into mine i'll never get it out. (but its been a helluva ride!!!)
Old 06-05-2007 | 01:14 PM
  #58
Stormrider's Avatar
OK... move up... good move.
and don't worry about recouping. it never happens.
Old 06-05-2007 | 03:52 PM
  #59
Ever try a Hydro P5X?
I did last Sunday and the handling is awesome! The top speed on my boat was down about 2mph though.
I have a used 25p sitting in my basement that is for sale, $600 takes it.
I'm going to give it back to the owner as I really don't have the cash to buy it right now.
I can put you in touch with him if you like. He is Condor 24 here on OSO but I'm not sure how often he visits.
Patrick
Old 06-11-2007 | 10:26 AM
  #60
Well I got to try the Rev 4 this weekend and my it was much better than a Bravo on my boat. Ran looser than a Bravo, much better bow lift and didn't lug the rpms down as much. I was actually surprised that I was able to pull the rpm I did with the prop. Very little slip too!
Boat ran 74 consistantly with a best of 74.7 running just over 5100. A couple mph slower than my Mirage but the handling and cruise was better. Mirage usually runs a consistant 76 at 5200. With a good lab hopefully I could be close to the Mirage's top speed.
