Props for a Pantera 24 >
Old 06-11-2007 | 10:52 AM
  #61
ziemer's Avatar
Is the Mirage a plus or regular? 25" right? And labbed?
Is your boat the sport model or an SE?
ziemer is offline
Old 06-11-2007 | 11:08 AM
  #62
onesickpantera's Avatar
Non-plus 25 that has had some work done to it. But I bought it used so I am not ure what exactly was done, but the blades are thin and sharp. I have a Sport.
onesickpantera is offline
Old 06-11-2007 | 02:14 PM
  #63
duunoit's Avatar
I ran a Revolution prop on my 24 and thought it felt real loose...
duunoit is offline
Old 06-11-2007 | 02:57 PM
  #64
It was definitely looser than the Bravo and the QIV, but I like to run a little loose. But not quite as loose as my Mirage. The Bravo threw my boat all over the place in the slop and needed a lot of trim.
Honestly, the best way I can describe the Rev 4 on my boat is the equivelent of a "4 blade Mirage".
Old 07-18-2007 | 08:18 AM
  #65
Pat McPherson's Avatar
Out doing a little prop testing last night...
2 guys, 1/2 tank, full cooler, 80°F, 10mph winds, a ripple - 6" chop.
First, a ø14.5" X 28p Mach Stern Driver 4 blade prop.
Top speeds:
73.1mph at 4600rpm into the wind.
74.0mph at 4700rpm with the wind.
Out of the hole, this prop broke free some and required a little bit of feathering. The boat ran nice and level with a good attitude. In hard corners the prop did start to brake free.
With a little tweeking to get the rpm up, I think the top speed would increase some.
Second, my labbed by BBlades ø15.25" X 28p Merc Bravo 1
Top speeds:
74.6mph at 4800rpm into the wind.
75.3mph at 4900rpm with the wind.
My B1 is still the best 4 blade prop that I've run on my boat.
Best top speed, best out of the hole, and does not brake free in corners...
Next up will be a stock 27p M+...
Patrick
Pat McPherson is offline
Old 07-18-2007 | 01:30 PM
  #66
T-Mone's Avatar
T-Mone
Great test results Pat. Sounds like you had fun last night wish I could have made down. I will definately make it out one for one of these tues, test days... Talk to you soon, Anthony
T-Mone is offline
Old 07-18-2007 | 02:56 PM
  #67
I agree, good results! Refresh my memory, are you running a stock 502 with Stainless Marine exhaust?
Old 07-18-2007 | 03:05 PM
  #68
Let's get together soon T.
I've got that labbed 26p B1 for you.
Patrick
Old 07-18-2007 | 03:12 PM
  #69
Yup.
A basically stock 1997 Merc 502MagMPI with Stainless Marine exhaust. I did rings, bearings, oil pump, and a valve job about 150 hours ago. When the heads were done, they did also have some pocket porting done. The cam is original so I think it probably only makes 25-30HP over an all a stock 502Mag with cast exhaust.
Patrick
Old 07-18-2007 | 03:27 PM
  #70
Originally Posted by Pat McPherson
Yup.
Then I'd say those are very good numbers!
