The rebuild of the Pantera coloured 509 >
Old 06-13-2007 | 04:24 AM
  #161
tomas_wallin's Avatar
Used that bad ass filler to glue the floor to the bottom and to the stringers and then glassed it in place around the whole thing with 3 layers of light chopped mat and one layer of combination mat (chopped mat and woven rowing)
Then topcoated the whole thing to seal it from humid and water. Now it's only the Perelli floor that needs to be glued in place.
Attached Thumbnails The rebuild of the Pantera coloured 509-sm_img_0945.jpg   The rebuild of the Pantera coloured 509-sm_img_0949.jpg
tomas_wallin is offline
Old 06-13-2007 | 05:54 AM
  #162
nice work Tomas.
that's quite a project
tomcei is offline
Old 06-13-2007 | 06:01 AM
  #163
Originally Posted by tomcei
nice work Tomas.
Thanks Tom!
Old 06-13-2007 | 07:05 AM
  #164
Nice job with the tank install ! I hope the foam doesnt compress when you put 800lbs of fuel in the tank and take it wave hopping ! If it does the tanks going to move and the tabs bolted in will break off ! Im sure you took this into consideration .
z.zuperboat is offline
Old 06-13-2007 | 07:21 AM
  #165
Yes it stiff as hell! That old foam was a bit so and so... Both the rear tank brackets had broke loose and the front one had cracks in the welds. This is at least a better solution than that.
Old 06-13-2007 | 09:52 AM
  #166
Dude! Sweet!'s Avatar
Tomas, nice work! I'm really impressed with the level of committment and the tidy workmanship. You're a lot braver than I am when it comes to boat repairs!
Dude! Sweet! is offline
Old 06-13-2007 | 12:38 PM
  #167
The thing is also that the tank on this Pantera is quite smaller than on most 28's to make it lower, so it's not gonna be as much as 800lbs even filled up to the top. The area of the foam plates underneath the tank is kind of big too, and since it's a pretty stiff material, as Tomas said, it will probably do the job. The idea is to provide support for the tank and the floor with remained flexibility. We have also welded the brackets on the tank all the way around them, instead of just on the sides, but anyway, thanks for pointing this out. I bet this baby is gonna be able to handle some serious waves out in the Baltic Sea this summer!
Comments from the fat dude, who's been busting his rear off all weekend
Dr. Phil is offline
Old 06-13-2007 | 01:43 PM
  #168
Cracked welds in the tank !! WOW Your lucky it didnt leak and burn ! If the tanks going to be stronger then so is the bottom of the boat . Nice upgrade guys
Old 06-13-2007 | 05:02 PM
  #169
Elite Marine's Avatar
Very nice job.
Maybe Jo and Pepe will rent us the molds and between all of us we can start pumping out huge HP Panteras!!
Elite Marine is offline
Old 06-14-2007 | 04:35 AM
  #170
Some clarification, it was just the welds that held the brackets. Not the tanks structural welds.
Thanks man! That's probably because we are a couple of craaazy Swedes...
The "fat dude" is of course correct. The fuel tank is at 90gallons (580lbs) so that together with the weight of the tank should add up to a total of about 650-700lbs.
