The rebuild of the Pantera coloured 509 >
Old 07-15-2007 | 05:09 AM
  #211
tomas_wallin's Avatar
Thanks guys!
We went with 28 deg timing to make it real reliable and 86/96 on the jets.
Ended up with 825hp@5800 and 815ft-lbs@4000 (the chart begins at 4000 and drops in a straight line to 765ft-lbs@5800 so we probably have about 840-850ft-lbs as the most.
This is with the waterpump and generator connected and real true numbers. Usually there are a 40-50hp difference from a dyno in the US from the ones we have here. Our ones are true corrected and real numbers...
tomas_wallin is offline
Old 07-15-2007 | 05:37 AM
  #212
nocigarette's Avatar
Sounds good.....Cant wait ti hear it in the boat.............
nocigarette is offline
Old 07-16-2007 | 03:01 AM
  #213
Sea trials today!
Old 07-16-2007 | 04:00 AM
  #214
Good luck, hope everything works as planned.
Magnus Z.
Magnus Z is offline
Old 07-16-2007 | 11:52 AM
  #215
With the motor broken in on the dyno we should have some real numbers quick ! Good luck and enjoy. As far as pullies for more boost adding teeth on the top will lower the boost not raise it.
z.zuperboat is offline
Old 07-17-2007 | 04:28 PM
  #216
Now it's in the water! We just went for a quick ride since it's been raining all day. It pulls real good!!! Did not connect the gps. Will go for a longer ride tomorrow, will post the results later!
Old 07-17-2007 | 05:25 PM
  #217
Elite Marine's Avatar
Looks like you did a real nice job on the engine. Great numbers. Let us know how your performance is. Take it slow!!
Elite Marine is offline
Old 07-19-2007 | 07:14 AM
  #218
Here are the dyno sheets
Attached Thumbnails The rebuild of the Pantera coloured 509-sm_img_1105.jpg   The rebuild of the Pantera coloured 509-sm_img_1107.jpg
Old 07-19-2007 | 08:03 AM
  #219
Registered User
Tomas the break specifics are where they need to be....
MIAMIBOYZ is offline
Old 07-19-2007 | 05:56 PM
  #220
Congrats Tomas!
thedonz is offline
