Engine won't turn over >
Old 03-25-2007 | 04:05 PM
ChristianGott's Avatar
you can check your slave solenoid by jumping directly to a battery...i forget the exact procedure, but if you google it, ti comes right up..i think the advice comes from theoutdriveshop.com
ChristianGott is offline
Old 03-26-2007 | 08:52 AM
ziemer's Avatar
As mentioned above check your neutral safety switch. I believe it's located near where the shift cable is attached to the exhaust. It should be a yellow and a yellow w/ red strip pair of wires. If you jump the two wires together it will bypass the switch.
It probably is not the kill switch, because even if it's unplugged the motor will still turn over.
ziemer is offline
Old 03-26-2007 | 08:00 PM
well.........
tomcei is offline
Old 03-27-2007 | 12:27 AM
The neutral safety switch should be connected to the shifter arm where the cables connect to the shifter. I don't think the volts would drop though if it was not engaging.
First thing to try is a battery. If that does not work, see if you can turn the engine crank with a breaker bar.
Griff is offline
Old 03-27-2007 | 07:49 AM
Courtholl's Avatar
I had to stop messing with the boat and start working on the house. Plus, I do not know my way around the engine as well as everyone else here. Especially when I would have to crawl around it. Going to try to call the tech that winterized it. Just pissed, as I am going to have to pay $90.00 to have the oil changed, just b/c I was not able to get it started. Or could I wait to change the oil when I get it back?
Courtholl is offline
Old 03-27-2007 | 11:45 AM
jeff32's Avatar
yes.
jeff32 is offline
Old 04-17-2007 | 11:22 AM
Courtholl's Avatar
Outcome was a bad ignition switch and selinoid. The mechanic noted that the distributer has a lot of rust in it. Noted that should consider dealing with ,etc. the MSD that is in it is for a car. Should I change this system completely, and if so, what recommendations does everyone have.
Old 04-17-2007 | 12:33 PM
CIG3's Avatar
Call Summit. You can buy a new pick-up msd-84661 $21.00 and msd-8415 reluctor wheel for $55.00. Check the gear while your ate it. That is all the parts unless you have mechanical advance. Spring kits are also available. A good cleaning once a year will keep it from happening again.
CIG3 is offline
Old 04-17-2007 | 04:57 PM
duunoit's Avatar
MSD will rebuild it for something like $75. My understanding is they send you a refurb with all new parts as soon as they get yours.
duunoit is offline
Old 04-17-2007 | 09:14 PM
Pantera24's Avatar
ditto rebuild it with MSD.
Pantera24 is offline
Splitdecision271
07-11-2008 11:29 AM
Rebel_Heart
8
07-06-2008 11:59 PM
twin242ls
3
07-15-2007 04:25 PM
JON242
18
07-01-2002 05:33 PM
