VON BONGO,  How's the progress?? >
Old 08-06-2002 | 08:34 AM
  #131
Stormrider's Avatar
JC Performance Engines
Von Bongo,
Maybe while your boat is still under construction, you can have a dipstick made for the fuel tank for accurate readings.
Stormrider is offline
Old 08-06-2002 | 05:42 PM
  #132
Originally posted by missingout
Von Bongo,
Griff is offline
Old 08-06-2002 | 08:21 PM
  #133
GaryMMM
VB, I too saw your boat. We may launch on the same day. If we do, let's take some break in pictures. Your fuel consumption problems may be alleviated by installing a fuel flow rate guage. I heard that these guages help to find the perfect trim and RPM for cruising. It was good to see my boat behind yours in the picture. I too am getting anxious to be on the sea. Maybe we'll see you in Miami. GaryM
Old 08-06-2002 | 09:07 PM
  #134
Von Bongo's Avatar
Hey Gary I saw your boat in the background too but I didn't say anything, I wanted it to be a surprise!
Turtle, it's getting a Myco steel trailer in white, red and blue! I don't think I will have any trouble with the fuel, the beak boat used to run out at 1/4 tank so I keep em pretty full.
I do not know if I will be able to get to Miami to test or not, I may just have to have Jo and Pete take it out and then get it on the road. I get back the friday night before the shoot out and I am trying to figure out how to get it there in time.
Oh and Gary, I don't think I am going to have any problems consuming fuel
Von Bongo is offline
Old 08-07-2002 | 08:40 AM
  #135
Stormrider's Avatar
Default Fuel dipstick
Originally posted by Griff
Griff,
The boat we have now, although not a high performance boat, was custom built. It has the fuel filler in the deck w/ a direct line into the tank. We had wood dipsticks made so you can unscrew the fill cap, and dip the stick right into the fuel. It gives very accureate readings. The other way to go is with a flow scan, which gives a reading of what the engines are currently burning and how much has been used.
I hope that clears things up.
There is nothing worse than running out of fuel, especially because most fuel gauges are innacurate.
Old 08-07-2002 | 10:11 PM
  #136
Von Bongo's Avatar
Are you going to the Shootout????
Hey Griff, that is the plan as we speak! Need to talk to Jo again, but I doing everything on my end to make sure I am in attendance.
Old 08-08-2002 | 03:28 PM
  #137
Von, where are ya stayin. My cell is 402-968-6635 so you have no excuse for not hanging with the OSO group this time
Griff is offline
Old 08-08-2002 | 04:14 PM
  #138
Von Bongo's Avatar
Griff,
I am going to stay at Lazy Days in e-11. Getting in real late on friday. Where are you guys staying?
Old 08-09-2002 | 04:34 AM
  #139
Staying at Holiday Shores-16.5mm in Port Arrowhead Cove from Fri-Fri, then going to Parkview Bay for Labor Day Wknd. Just into the Grand Glaize Arm past the bridge( so I'm told).
BTW, I posted my home # earlier, the cell is 402-968-6635.
Griff is offline
Old 08-10-2002 | 12:00 AM
  #140
dangerkitty2's Avatar
VONBONGO...........
Whats a Shoot Out??
dangerkitty2 is offline
