prop slip question >
prop slip question
prop slip question
Old 10-14-2013 | 09:22 AM
Default prop slip question
What kinda of slip numbers are you guys with 28's seeing? Mine is about 17 which seems a little high.
The Get Away is offline
Old 10-14-2013 | 09:26 AM
mgh
what kind of mph are you seeing out of that boat? prior owner said 97mph..
mgh is offline
Old 10-14-2013 | 09:41 AM
No where close to that. GPS on my phone yesterday said 82 at 5800rpm with 4 adults and 3/4 tank of fuel against the river current. I don't think it has 97 in it.
Old 10-14-2013 | 12:49 PM
When I had my 28, the propslip was in the 17% range also and that was after adding another inch of spacer and propwork.
Griff is offline
Old 10-16-2013 | 07:44 PM
Was that the best for the boat performance wise or did you just settle for that? Anyone else.
Old 10-16-2013 | 08:11 PM
cant compare to Griffs old boat. his was a single. 17 is a little on the high side for twins. my 94 bravo boat was in the 10-12 range running 4 blade 26's bravos.
88bullet is offline
Old 10-17-2013 | 01:28 AM
I feel like im losing quite a bit of speed with that much slip, or is that just wishful thinking . Im running 27p hydros now which I hate, they want to porpoise real bad. I borrowed a set of 30p bravos earlier in the year and was able to turn those to 4900rpm, I was having some other issues that day so I didn't get to do a whole lot of testing with them. I think a labbed set of 30's would be the ticket.
