24 pantera etc.  what kind of speeds from how much power? >
Old 02-16-2015 | 06:29 AM
Default 24 pantera etc. what kind of speeds from how much power?
mine is a TRS boat now, but probably won't stay that way for more than a year or two. probably getting 450 or so hp jumped-up L29 for it's first engine. just wondering everything from 260-alpha to about 700 hp-high xdim-imcos and even a few arnies have been put in these hulls. just wondering what the end results come out to. edit; tomas wallin's numbers don't count. i don't have 5 years to blueprint my bottom.
dereknkathy is offline
Old 02-16-2015 | 02:38 PM
Ing's Avatar
Ing
Veteran: Marine Corp
I have TMONE's original 24 Sport. 509BBC, 575hp with Bravo 1. 80mph running a Hydromotive P5X 15x25 at 5800rpm's. Some of the gear heads say there is more to be had from this setup but 80mph is plenty for me. LOL
Ing is offline
Old 02-16-2015 | 03:36 PM
Stormrider's Avatar
JC Performance Engines
I had 560hp in an 1995 24SE, spinning a 23M+ approx. 5700rpm.
I saw a best of 75, but the next few owners saw closer to 78-80.
Stormrider is offline
Old 02-16-2015 | 06:44 PM
you know, with a few samples we might be able to create a speed-hp calculator since it is a pretty big cross section of very similar-i hate to say identical-hulls.
Old 02-16-2015 | 07:07 PM
vintage chromoly's Avatar
I'm hoping to get my junk into the high 80's.
Projected HP is 650ish.
I flipped my hull and straightened the bottom to the best of my ability.
Time will tell, I suppose.
vintage chromoly is offline
Old 02-16-2015 | 11:58 PM
V.C. werent you in touch with Tomas when you did your bottom or maybe I have you mixed up with someone else? Your pictures look great, we are looking forward to hear how she runs .
JAIME is offline
Old 02-17-2015 | 04:19 AM
I didn't corespond with Tomas but I read his thread more than a few times.
I'm sure my hull is heavy as its a really early one.
Hopefully, by this summer, I'll know.
Thanks for the compliment.
Old 02-17-2015 | 08:52 AM
24 Pantera TRS mirage 23p said to be 400-425hp would flicker 70mph light fuel 1 person. Two people with fuel 68mph was the norm.
Nmbr1GMfan is offline
Old 02-17-2015 | 09:37 AM
took glance at your build thread. warmed over 330? that looks like a rect single plane intake. still oval heads and flat pistons?
Old 02-17-2015 | 02:42 PM
My post was with the old setup. New setup hasn't been propped or run hard yet.
