Relocating Trim Switches/Indicators >
Old 04-02-2003 | 08:28 PM
Elite Marine's Avatar
Default Relocating Trim Switches/Indicators
Has anyone mounted either Trim Tab Switches or an Indicator in the space on the right between the instrument panel and the windshield?
I would like to do this to make a nice new panel, but don't want to compromise the integrity of the boat.
See attached:
Elite Marine is offline
Old 04-03-2003 | 04:11 PM
JO - PANTERABOATS's Avatar
Hey Kirk,
You will not have a problem with mounting an indicator panel there.I would look into the Stainless Marine indicator panel since they are smaller in length and width.You will need to move your front bolster out of the way to do the installation.I dont see any advantage of also moving the 3 rocker switch panel on the dash now.The Stainless Marine indicator panel also come finished in Purple powdercoating.Take a look at their website and give Brownie or Jerry a call at 305-681-7893.
The Steering wheel your boat had before was 12.6 diameter while your new wheel is 13.8 diameter which does not allow much room with your hand and throttle arm on your bolster.
Regards,
JO
JO - PANTERABOATS is offline
Old 04-03-2003 | 06:33 PM
Indy's Avatar
Member #154
Geez...how's that for customer service Jo, you're a role model for customer service in an industry plagued with mediocrity.
Indy is offline
Old 04-03-2003 | 07:59 PM
Thanks Jo!!
The reason I'm moving the switch is so that while underway with the bolster down I can reach the switches!!! Also it would free up the space on the panel as I need to add several instruments - Boost Pressure Gauge, Fuel Pressure Gauge, Oil Temperature, Depth Gauge.
Indy - Imagine the support I'll get when I buy a new Pantera from Jo!!! I bought this one from a customer of his!
Old 04-03-2003 | 09:14 PM
Hey Kirk,
If you need to have a custom trim switch panel made let me know and I will put one together for you.The indicator panel Stainless Marine will be the way to go for you and I think you will like the purple color to match the rest of your boat.
Hey Indy,
Thank you !!!
I try to give as much support as I can to our customers.
JO
Frank Galasso
Do It Yourself, Boating on a Budget
2
02-06-2008 08:22 PM
truckone
01-23-2006 12:47 PM
GregP
04-14-2005 06:59 PM
Audiofn
06-16-2002 09:49 AM
hauling ass-a
05-06-2002 01:35 PM
