RPM / Prop / Speeds >
RPM / Prop / Speeds
RPM / Prop / Speeds
Old 04-06-2005 | 08:17 AM
Pat McPherson's Avatar
Default Re: RPM / Prop / Speeds
Pat, how could this be checked... its a new Livorsi.
Could it be the sender?
How can I make sure its right on this time around?
I would suggest to compare to a second tach. There is no real sender, it's just a signal wire from the distributor. Your engine builder will have an easy way I'm sure.
Patrick
Pat McPherson is offline
Old 04-06-2005 | 08:25 AM
Stormrider's Avatar
JC Performance Engines
Albert, how much HP/Torque you running?
Thanks Pat.
Stormrider is offline
Old 04-06-2005 | 10:40 AM
Registered User
Thanks Pat.
700/720
Keep in mind, I have a very light 28 race lay up with a notch transom not to be compared to any pleasure 28....
MIAMIBOYZ is offline
Old 04-07-2005 | 12:16 AM
panteraman28's Avatar
Im running a 31 pitch at 6200 rpm and saw 98mph
panteraman28 is offline
Old 04-07-2005 | 04:10 PM
T-Mone's Avatar
T-Mone
Hey guys I am running a labbed 27 pitch mirage plus at 5600 rpm and 81.7 on gps that was in Tampa Bay 83 Deg High humidty. I will be posting info on my prop session with Throttle up and hydromotive over the weekend.
T-Mone is offline
Old 04-07-2005 | 07:18 PM
Stormrider's Avatar
look forward to hearing it anthony.
I've heard(from JO) the hydromotives tend to give stern lift, where the pantera 24 likes bow lift.
What torque you running?
Old 04-07-2005 | 08:00 PM
Elite Marine's Avatar
Ran 82.8 with a 25P Mirage Plus @ 5400 RPM on the limiter
Ran 84.7 with a 29P Mirage @ 4700 RPM
Ran a 27P Mirage Plus but GPS batteries died!!!
Elite Marine is offline
Old 04-08-2005 | 08:06 AM
Stormrider's Avatar
I saw this on the Gen Disc. board, but how do you compare a B1 to a Mir plus?
They were saying a 25mir+ is like a 24B1.
Old 04-08-2005 | 08:35 AM
T-Mone's Avatar
T-Mone
Hey storm I have the dyno sheets in front of me. I will give you the numbers that are the closest to how the engine is tuned for reliability wich is the way I have it set up in the boat.
(5000)- 542 HP 569TQ (5500) - 567HP 542TQ
(5100) - 547 564 (5600) - 571 535
(5200)- 553 559 (5700) - 572 527
(5300) - 559 554 (5800) - 576 522
(5400) - 564 548
T-Mone is offline
Old 04-08-2005 | 08:39 AM
T-Mone's Avatar
T-Mone
Hey sorry that post look like a bunch jumbled numbers but I am sure you can figure it out. Anthony
T-Mone is offline
