Powerplay Boats
#1381
#1384
#1385
The Powerplay was Danny's design and from a clean sheet of paper, the hull was tested and changes were made then it was tooled.
My personal vented system is a little different than Modifying an existing boat.
The Pantera Group has good running 41 Stepped Vee
One of our local Builders Pat at AT builds a 37 with his as AVH bottom or as a straight Vee. Look at the photos of it running very nicely done a single step DDC Schoell Bottom.
Fabio Buzzi's Boats run very well with his Bottom in mountainous seas.
The Speed record is held by a step Vee and Boats from Fountain run very well.
#1386
There was a simple way to get the bottom running on a "Air" Film without any radical geometry changes which was the approach I chose which made a lot of things easy from handling to trailer bunk considerations.
Someone probably had the same Idea long before I did.
#1387
#1388
Beautiful Blue water down there you guys get to play in.
#1390
