280 Silencer Chime Walk
At 73-74 MPH my 280 Silencer 2000 starts to chime walk from left to right.....At that point I have to shut it down.....I'm thinking about a charger but I'm concerened the boat will be unsafe if I go faster.
When it starts to chine walk do you drop the tabs a touch???
NTP ;) |
By the way, What do you have powering this Silencer???
NTP :confused: |
I'm running a 502 and I never did move the trim tabs down....I have them set at the top speed the boat will go......I was thinking maybe K-planes.........
are you running a stock 502? or???
are you reading speedo speeds or GPS? My stock 280 with 502 (stock) sees a maximum of 65 mph and I have just a touch of side to side walk which I settle by pressing the tabs down just to the level position and it runs just smooth. K-planes, sure they would be nice but as a rule are not required on the 280 since most of the speeds are under the 70 mph mark. Jeff |
My 280 never had this happen. Step hulls will have a very slight bit of side to side. They call it tick-tock. But always felt 100% in control. No tabs were needed. You may be triming it too high?!?!? Mine ran best the the trim needle JUST above the first mark on the gauge.
The engine is a 502 500hp I'm running a 28 pitch prop Lab FINISH $1,300.00 BUCKS...I JUST INSTALLED an MSD.....which helped a litle in the mid range...but did nothing at the top end.....I also had the boat's hull blue printed at the factory....$2,700.00....prior to delivery........the speed is 74 on a GPS and the boat walks left to right at that speed.....thanks for the reply
| All times are GMT -5. The time now is 08:07 AM. |
