Go Back  Offshoreonly.com > Owners Forum > Powerquest
26 Legend Owners >
26 Legend Owners
26 Legend Owners
Old 12-16-2006 | 09:07 PM
Fast Forward's Avatar
Default 26 Legend Owners
Just curious if anyone with a 26 Legend has removed the ventilation plus in the prop? If so pro's or con's???
If no 26 owners anyone else??
Fast Forward is offline
Old 12-17-2006 | 08:51 AM
Default Re: 26 Legend Owners
I removed them on my 29 and didn't like it.The props would
break loose on take offs.but the 260 might be different
boatnt is offline
Old 12-17-2006 | 09:00 AM
My 260 didn't have them. But I know what you are talking about. They would not help on your boat. They are for boats that have a hard time getting on plane. And the 260 does not have that problem. They ventilate the prop to bring the rpm's up.
Gary C is offline
Old 12-17-2006 | 04:53 PM
Getting out of the hole is no issue at all. I wonder if I would be able to spin a larger prop by removing??
Old 12-18-2006 | 01:51 PM
You need HP to spin a bigger prop. You might be able to get on plane with the plugs removed on the bigger wheel. But if you don't have the HP you will not get it to spin to the max RPM's An example, I tried a 24 pitch Bravo 1 4 blade. I was able to get up on plane no problem, but I could only spin it to 4500 rpm's. I wound up getting my 21 Mirage Plus reworked to a 22. I could spin it to 5000. That was after an exhaust and aircleaner change.
Gary C is offline
Old 12-18-2006 | 04:55 PM
Thanks, Gary. After I posted that I got to thinking and came to the same conclusion. Gotta make more ponies.
Old 03-09-2007 | 06:30 PM
Question Subwoofers
Does anyone know if you can fit a 12" subwoofer under the back bench in a stryker/legand??? I need about 14" for it to work..
bigdaddyquest is offline
Old 03-09-2007 | 07:22 PM
I've got two 10" subs and two 6.5 under my back seat. Not sure but I would think anything larger than a 10 may start to create structural issues.
Old 03-09-2007 | 07:32 PM
Thanks for the info...do you think it would fit?? How much room do you have with your 10s??
Thanks again!!
Old 03-09-2007 | 07:36 PM
You may have. Here's a pic of my 10"
Attached Thumbnails 26 Legend Owners-speaker%2520grills%2520005%2520%2528small%2529.jpg
