Go Back  Offshoreonly.com > Owners Forum > Powerquest
26 Legend Prop Testing info >
Old 07-30-2008 | 11:40 AM
Fast Forward's Avatar
Default 26 Legend Prop Testing info
Well we finally got a nice day on of the big pond to do some prop testing and I thought I'd share some results.
454Mag EFI
Water condition: Less than 1'
Water temp : 71deg
Air temp: 88 deg
23p Mirage plus 3 blade:
3000 RPM....35mph.....tab 0
4000 RPM....50mph....tab 2
4550 RPM....57.5mph....tab 2
Over 50 trimmed in flat water the boat did have some chine walk. Nothing major but became a drivers boat at that point.
23p Hydromotive Q1V plus 4 blade:
3000 RPM......34mph.......tabs2
4000 RPM......50mph...... tabs2
4600 RPM......60mph.......tabs2
Over 50 with the Hydro was all in all a nice stable in controlled ride with nearly no chine walk. With the 4 blade it seemed to like more trim as well as tabs. Unlike the Mirage Plus, dropping the tabs generally yield a 2-3 mph flow down. The Hydro 4 blade yielded an increase in speed.
My guess is in a 1-2' chop I should see about another 2-3 mph.
I've also got a 21p Mirage Plus but ran out of daylight to test in the same water condition. However I know based on last year I obtained 59mph at 4900 RPM.
Thus all around the Hydro was the best pick allowing me a higher top end number while running at a lower RPM.
FYI. I did run a Bravo 1 22p 4 blade last year which the boat did not like at all. To much bow lift and seemed to only make the chine walking worse at speed.
So if anyone's interested I have a nearly brand new Mirage Plus 23p I'm going to sell. It does have Baja etched into the hub.......... I know what you PQ owners are thinking , no smack talk.
Fast Forward is offline
Old 07-30-2008 | 12:14 PM
Knot 4 Me's Avatar
You have a 454MAG, correct? If so, why do you only want to turn 4,600RPM?
Knot 4 Me is offline
Old 07-30-2008 | 12:22 PM
You are correct.
I'm sure the boat won't spin anything larger than a 23, however according to Hydromotive if I have a lab finished done I should see another 200 rpm and see another 2-3 mph.
Looking at where I came from I'm very happy top only spin 4600 and obtain a higher top end number.
Top end was not so important as all around handling. Which I really got better results all around!. Can I squeeze out more top end?? I think theres a little more to be had . Question is do I want to spend a little more money to obtain when I only run wide open 1-2 times a year. And thats just for a short run.
Fast Forward
Prop Talk
10
05-24-2015 02:39 PM
NashvilleBound
Prop Talk
5
05-09-2007 06:05 AM
Fast Forward
Powerquest
3
08-17-2006 01:37 PM
Fast Forward
Powerquest
16
06-19-2005 12:34 PM
HOTTZU98
Powerquest
5
05-09-2005 06:42 AM
