2mph more with Hydromotive
#31
I ran a Mirage plus in both 23p and 21p on my 26 . In deed it was a great prop and I tried everything else under the sun. But the Hydromotive was the mack daddy on my 26. It turned better numbers all the way around plus the handling of the boat was much better. Could come down to drive and engine wear, humidity, altitude and a number of other things.
Im in Seattle which is sealevel so I would think your RPM and power would be even worse. I ran my boat in Idaho at 2100 ft elevation and could only get the RPM to 4300 and 55 MPH with the Hydro Quad IV. This is what really got me to thinking I needed a new prop.
All I can recommend to anyone out there is to see if you can try some different props before spending your money! I spent $650 on my Hydromotive PLUS $80 on the hub--$730 total only to have the wrong prop for my boat. Lesson learned!
#32
Im really suprised to hear that because from what Ive read the Hydromotive Quad IV is a stern lifting prop and great for stepped hulls but not good for a conventional bottom. A conventional bottom runs best with a bow lifting prop such as a Mirage Plus (23P) or Bravo 1 (24 P).
#33
I have a pair of quad 4 hydromotives right and left 23p both perfect. I only bought them as a pair and needed the right. I want to sell them to get the quad 4 x as I am running these on an older powerquest and want the bow lift not the stern lift. Make me an offer on them if interested
#34
I have a turbo made by hydromotive its a 24 3 blade gave my stock boat same speedas my 25mirage but at 23 mirage rpms. so if anyone wants it 250 takes it. also the merc rev 4 is a nice 4 blade bow lifter. art
#35
