-   Powerquest (https://www.offshoreonly.com/forums/powerquest-49/)
-   -   Raypanic splashdate!!!??? (https://www.offshoreonly.com/forums/powerquest/23518-raypanic-splashdate.html)
Scott 05-02-2002 08:17 AM
Ray,
I'm starting to think I may beat you to the water this year:p
I've recieved all my parts and will have some time off to start assembly of engines:cool:
Better hurry up!!! or are you still looking for the skinny person:p
Raypanic 05-02-2002 08:50 AM
I think I got it set I just have to remount the drives now. I fiddled with the alignment tool and pushed a little harder on it now it goes all the way in and out, Not with two fingers but I have to pull it with my whole hand. The other drive is dead nuts on and the tool goes in easier. This one takes a little more effort but I think with all the B.S. it is going to take to adjust the motor I will just let it go. I will be installing the first drive maybe today, But I have a "talent show" to go to tonite for my daughter. By the weekend for sure I will have the drives back on. After the drives are installed I need to Bleed the trim cylinders and Hydraulic steering. And I am waiting for new tie bar parts from BAM before it will be ready.
I need to figure out how I am going to run it on the hose I dont think the merc LWP Boot will work on the IMCO's and they dont make one either. I figured I would hook up a pair of rubber boots with a hose coupling in it :D
Then I need to finish the Hot Water heater (Tyler Removed) and pump hook ups. I ordered a Isotemp hot water heater I am still waiting for it to come in. I plan on mounting under the rear bench on the Port side pushing it as far in as I can. Once it is ready for the water this may be a next winter project depending on timing.
My marina does not start service untill May 15th, I may be ready for that following weekend. :D :D :D
P.S. Take lots of pictures!
Raypanic 05-02-2002 10:21 AM
1 Attachment(s)
here is how close I am to putting on the drives, Just need a little time
MikeStar 05-02-2002 01:06 PM
Ray, I like the 16 pound "Drive Installation and Alignment" tool leaning up against the transom...
"This *BAM* drive *THUD* is *WHACK* gonna *BOOM* fit, dammit!" :D
Raypanic 05-02-2002 03:17 PM
Sad thing I had to use it to get the gimble bearing in. It only took about 4 hits!:D
Well now I have had another setback :mad: :mad: :mad:
http://www.offshoreonly.com/forum/sh...threadid=23543
When will it end!
Scott 05-02-2002 05:41 PM
Ray,
I was getting ready to post a crack about the sledge then I saw your post:eek:
I will make a couple of calls :confused:
Raypanic 05-02-2002 06:30 PM
Thanks Scott but I allready decided to buy a new one, I called Marc at BAM and he is getting one right out to me.
I also called Tyler about the engine alignment, He said bring it up to him on saturday and he will take care of it while I wait. Cant beat that.
Scott 05-02-2002 07:17 PM
Well I guess you can disregard my email:rolleyes:
Thats great he is willing to help you out. Guess there are still some good folks out there.
I just had a positive experience with JimV from the board. They have been honest and helpfull. Can't wait to try out the new heads and cam combo!
Scott 05-02-2002 07:19 PM
Don't you have to pull the motor to replace that assembly? Or am I not thinking clear on how it's attatched:confused:
Raypanic 05-02-2002 09:43 PM
Nope thank god, It is just the Bell Housing, The actual part the drive bolts up to, I have to remove the pivot pins from the left and right side, Water feed line, drive fluid hose and driveshaft bellows. No big deal......we will see.
