Go Back  Offshoreonly.com > Owners Forum > Powerquest
PQ General Discussion >
Old 03-05-2011 | 04:32 PM
  #991
Additional pic
Need4SpeedGTCS is offline
Old 03-05-2011 | 05:15 PM
  #992
Originally Posted by ajfisher
Damn Verbi are you pushing drugs?? Dropping money like its HOT!! You gotta get me a job doin what you do so I can move up to the big chit
Is that a 450/550?
I only sell to the school kids, I have my morals!!
Truck is an '09 450, grey leather with nav and back up camera and has 27K.
I sold the 280, the Camaro, the GTO and the sled so I'm not out of pocket a whole lot!!
verbi69 is offline
Old 03-05-2011 | 05:31 PM
  #993
Originally Posted by Need4SpeedGTCS
Nicccee!!!
'08-'10 6.4l make sure there are no coolant leaks! Rads go out of them faster than I go through fuel. Rad is only one symptom of cooling system issues...any air in the cooling system and the front cover and water pump cavitate. Front cover perforates then coolant in the oil and then it grenades!
Other than that a beast on fuel, but tons of power and you won't even know the 38' is behind you.
I've heard a lot of mixed reviews on these.
I think I will do the DPF delete and tuner to help with the mileage.
verbi69 is offline
Old 03-05-2011 | 05:33 PM
  #994
Additional pic
What kind of power is the intercooler good for , 150??
When your done send 'em my way!!
verbi69 is offline
Old 03-05-2011 | 08:45 PM
  #995
Wink
Whipple claims approx. 100+ Hp with reprogammed ECM. I'm looking also for increased reliability/longevity. Already get 84mph on gps...but props are wrong...max out at 4800-4900 rpm; should pull 5100-5200. We'll see soon with the overhauls completed now too, may be able to keep the props. If all else fails I'll get that vortec paint
Send another teaser pic soon! lol.
Yes, the DPF delete will cure the fuel economy issue, no more regen; did Ontario drop the emissions testing?
Keep an eye on your coolant level in that rig! and keep the oil changed too; injectors weep into the crankcase.
Old 03-05-2011 | 10:27 PM
  #996
It will be interesting to see the results of your rebuild!!
I honestly cant say what years or types of vehicles need to go in for emission testing, I may be in for a surprise but I don't think so at this time.
verbi69 is offline
Old 03-05-2011 | 11:41 PM
  #997
That 6.4 if it has had the proper recall done on it will have no issues the radiator was not the issue it was a t valve that caused the problem n if it is fixed u r good. Used to work at a ford dealer. Strong motor with no issues other than stated.
cpiefer06 is offline
Old 03-05-2011 | 11:57 PM
  #998
The venturi tee installed on the recall was to help coolant flow pull air out of the system and reduce pressure pulses that cause the rad seam to let go, etc, etc. ('09 m/y should have tee from factory). Watch for rad hose leaks, the o-rings flatten out but only leak when running. Static or pressure tested usually okay; look for coolant staining at the connections.
Other than mentioned, yes a brutally strong stump puller. lol. Just stay on top of the maintenance!
OK, said way too much...enjoy the truck! I need one myself...and never mind sending my engines your way...new tow vehicle and I may be terrorizing a lake near you!
Old 03-06-2011 | 02:45 AM
  #999
Take It To The Max, Duramax!
THE 288 KID is offline
Old 03-06-2011 | 08:23 AM
  #1000
Warranty work comes up good, I'll keep on top of things and keep my fingers crossed....lol.
If you ever come down this way let me know!!
Mike.
verbi69 is offline
