PQ General Discussion
#1472
Man that sucks! I remember the first scratch I put in my brand new sunsation. Even worse they are most likely gonna spot your gelcoat so you will always have a sign of repair. If at all possible have them fix the spot and base it and clear the whole side. That way it will never come back...
Last edited by POWERPLAY J; 04-10-2011 at 03:40 PM. Reason: damn auto insert on EVO. lol
#1474
#1476
spotting is where they will fix the area and spray gel then blend it out then rub back the blend so its not visible. After a while and the more you polish/rub the boat the blend will pull back. Sometimes the gel they use will discolor and there will be an area that is off color. You have a very nice boat so do some research before you have any work done. Fyi if it was mine I'd do base/clear so I never have to worry about it coming back. BTW I do this for a living if it matters...
#1477
#1478
Registered User
Take your time and speak to people near you that are great for this repair get their take on it! Ask what method they use or would do?
#1479
Bert
a good boat repair shop could repair that without a halo,get a hold of Glassdave (member on board)and talk to him
repair it and if it ever comes back you have the option to clear it then..
and J is correct if not done right you will be able to spot the repair,no one else might be able but you will be and thats what counts..
#1480
