-   Powerquest (https://www.offshoreonly.com/forums/powerquest-49/)
-   -   Any Vyper 340's with 500 efi's? (https://www.offshoreonly.com/forums/powerquest/241712-any-vyper-340s-500-efis.html)
verbi69 10-31-2010 07:43 PM
At 75 -80 mph I dont think I would want to jamb the breaks on or have to do any evasive maneuvers...lol. Wonder why the dually would squat so much?
boatnt 10-31-2010 09:22 PM
Originally Posted by NKissau (Post 3243253)
I trailer my 38 every weekend no matter where I go. I have a 2500HD Duramax extended cab straight axle. I have air bags on it, truck doesn't squat an inch. Plenty of power and with good trailer brakes its no big deal at all. It cruises 75-80mph at 12mpg. I've actually pulled it with a Ford dually powerstroke and hated it. Truck squatted and it kept downshifting.
what brand boat trailer do you have,surge or electric over hydraulic brakes?
PWRQUEST 10-31-2010 10:12 PM
The difference has to be in the trailer. I have a 2500 HD crew cab with the 8.1, gets around 7 mpg towing. It has plenty of power but the trailer doesnt follow very well. It is a pacific trailer that was made for the boat.
RaceRPM 11-01-2010 06:47 PM
I trailer my 38 with a 2000 Ford F250 Crew Cab with single axle and it pulls very nicely. I can cruise all day at 70 mph and get about 10 - 11 mpg (thanks to the old 7.3L with some after market items). Very little squat and no issues with cross winds or passing semi's. The trailer is a Heritage triple axle and has outstanding brakes.
PWRQWST 11-02-2010 08:14 AM
Pulling a 38 over a 34 you will not even notice a differance. I pulled mine with a 2005 crew cab duramax for 3 years through the hills and turns of the Ozarks all the time and NEVER had any issues with it at all. I now own a ext cab 6.0 to pull it when I need to, but for the past 2 seasons it was on a lift in the Ozarks. You do NOT need a dually, unless you actually just want it. Mine sits on a Integrity trailer and overall length is 45 ft. I hold a CDL and when I use to drive pulled tandem trailers so I do have experience with pulling things. As for brakes I have serge, and again if set up correctly you will have no issues stopping or making fast moves. Again if you have ever drivin to Lake of the Ozarks you would understand taking some fun curves at 70 MPH and people pulling out in front of you or deciding to stop and turn right in front of you.
I also have friend with boats just as big or even bigger and non of them own a dully. A 42 Outerlimits with a crew cab F-250. Or a crew cab 6.0 chevy for a 35 Cig.
Good luck in what you get
verbi69 11-02-2010 04:30 PM
I am eyeballing a 2002 Vyper that is listed in the classifieds which has 496's but really wishing it had 500's.
I think a 3/4 ton diesel would be enough truck.
VYPER2000 11-04-2010 08:14 AM
Good day, i have a 2000 vyper with the 500 efi blue engines running 30 pitch labbed props, the best it runs on gps is 78 mph at 5200 rpm
boatnt 11-04-2010 08:32 AM
as you can see not much different in speeds ,and if you leave the 496s alone/stock they are bullet proof with less maintance then the 500s
verbi69 11-04-2010 10:04 AM
It is very hard to leave well enough alone though, but your right!!
PQHunter 11-06-2010 12:08 PM
I have a 99 34Vyper with 500 EFI's 4 blade 30 pitch not labbed props, do you think that would cause prop wash on take off. I have alot of issues with take off in big water.
