340 Vyper Question
This boat and any salt water boat with fresh water cooling/closed loop will look and perform the same way as a fresh water boat. Especially if it's maintained properly.
This one was dry stored, cleaned and flushed after every use. It looks and is maintained better than most including freshwater boats. If you don't agree I'll give you $500 for the travel.
Here's the data on mine
2002 PowerQuest 340 Vyper
Twin step offshore powerboat
Always indoor stored and meticulously maintained with open checkbook
Boat listed at $220k when custom ordered
Owner has entire factory build process documented
Custom logo's on sides, windscreen and bow
Detailed and waxed
MerCruiser 496 Mag HO's
Amsoil synthetic oils
K&N air filters
MerCruiser Bravo One X Drives
K-plane Trim Tabs
Latham Full Hydraulic Steering
Drive Showers
Corsa Quick and Quiet Exhaust
Custom exhaust tips
Mercury Labbed Stainless 28p Props
Swim Ladder
Swim platform shower
Pull up cleats
Automatic Fire System
Drive and Trim Indicators
Livorsi Throttles and Shifters
Livorsi Redline Gauges w/ custom colors
GPS Speedo
Momo Steering Wheel
Custom painted dash panels
Depth Finder
On-Board Battery Charger - 30amp
Drop Down Front Bolsters
Dual Optima Batteries w/switches
Custom battery boxes
Shore Power w/cord and pigtail
JL Audio Stereo System w/2 subs, amps and remotes
Cabin Galley with Stainless Sink, Microwave, and Fridge
Marine A/C and Heat
Hot Water Heater
Vacuflush Porcelain Head
Macerator w/ overboard discharge
Newly refinished cockpit w/ custom options and logo's
Full lightweight Cockpit Cover (NEW - Aqualon)
Full Sunbrella cover (NEW in box)
Custom colors and one of a kind
Painted windscreen with PQ graphics
PQ graphics on bow
New raw water pumps
New shift and trim cables
Many extra parts including spare drive
Coast Guard documented (no state registration required)
This PQ is a one of a kind, custom ordered, high performance, off-shore phenomenon. Full picture documentation of boat during construction at the factory and all records and receipt history are available. It has always been dry kept and covered when not out on the water. With the largest headroom at 5’6” in the cabin for any boat in its class, it makes it a comfort to entertain. The list of customizations is a mile long. They are as follows...
Twin 496 Mag HO engines (425+ hp each) with only 240 hours
Twin Bravo X drives (1.5 ratio)
Simrek custom drive showers
Race Kiefkaffer K-planes with hydraulic controls
Mercury labbed 28P Bravo propellers (80 mph on GPS)
Special K&N filters
Full Latham hydraulic steering to helm (option)
Immaculately maintained/new condition with all records
Only 240 hours on closed loop cooling
GPS speedometer w/recall
Flushed and washed each use with Salt Away protection system
Fully maintained/new condition with open checkbook
Engine and drive use synthetic oil changed every 30-50 hours
Custom paint/graphics
Custom colored interior with bolster seats and logo's (new 2011)
New Optima gel-cell batteries (2)
Custom JL Audio stereo with subwoofers and remotes (helm and transom)
Custom 3 color painted dash panels w/logo
Custom gauges with color bezels
Custom throttles/shifter
Custom tilt steering wheel and colored hub
Custom straight exhaust tips
(2) covers – 1 new Sunbrella, 1 new Aqualon
Pull-up cleats (option)
Full hot/cold water option with 25 gal tank
Transom shower/full shower in stand up head
Full porcelain vacuflush head with holding tank
Overboard discharge macerator
Full A/C heat in cabin
Full galley with power inverter
Battery charger
10 year hull warranty
Detailed and waxed
K&N air filters
K-plane Trim Tabs
Drive Showers
Custom exhaust tips
Swim Ladder
Pull up cleats
GPS Speedo
Momo Steering Wheel
Depth Finder
Marine A/C and Heat
Hot Water Heater
PQ graphics on bow
New raw water pumps
Special K&N filters
Battery charger
You should look hard at Vyper 340's boat, you will not find a nicer and we cared for boat. I IS worth your time. Fresh water cooler motors run antifreeze, not salt!
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
I have been speaking with him.....looks like a hell of a boat!!
