on one of my 290s I also went with a set of 4 blades Bravo 1 26 props..that helped out alot but lost 1-2 on top end but at take offs and midrange they were great.
Originally Posted by boatnt
(Post 3498985)
No, i appreaciate all your knowledge, i wish i new more of what is in the motors. I was afraid to put that up here, because its way faster than i ever thought it would go.
When i bought it i was hoping for 71 - 72 i also run 25 props and turn 5200 You descibed to me exaclty what it's doing...its scary at times. I just bought a set of 380 k planes, im going to have them put on over the winter. ( Potter Engine) i mentioned i was chatting with you on line, and he told me to ask you about turning the props out, or in, which is better on that boat? |
You should be spinning out...I tryed spinning in and made it hard docking..no gains that I could see..
Originally Posted by AngerMgmt
(Post 3498987)
I have those props and Imco -2's...........no chine walking, FYI.
the 290s like to ride with the nose high kind of a$$ heavy..the 4 blades lift the stern and give it more of a level ride ..better ride,less chine walking,,more boat in the water= 1-2 mph loss at top end....which if you ask me its worth it.. |
would the 26p give me a little better top end?
I hear you on the Chime walk. Some times it's bad to the point you have to back off of it, yet other times you can ride right through it. |
booatnt - thanks for your help, i appreciate it.
i'm going to check which way they are spinning - at top speed, it may be causing it to chime more than normal?? one other question - do you send your props out to improve them? |
502's should run mid 70's with Labbed props... I have 7.4's and I can run high 60's with a best of 69.5gps. Kid 288 saw the gps screen himself also
You need to run 3 blade Labbed props to get speed out them though, the speeds boatnt posted are with 4 blades |
i have 4 blade 25's on it now, and i have miage 3 blade 25's also - should i send them out?
do recomend anyone ? what it the est cost? |
I never had the props labbed on any of my 290s but last year I had to props labbed on my old 300 and gained 2mph...went from 78 to a little over 80 on gps..I would think the same goes for the 290s...
Bblades seems to be the guy to go to with any merc prop |
| All times are GMT -5. The time now is 08:14 PM. |
