Go Back  Offshoreonly.com > Owners Forum > Powerquest
Bought a 29 Enticer >
Bought a 29 Enticer
Bought a 29 Enticer
Old 02-13-2005 | 10:48 AM
270Laser's Avatar
Default Re: Bought a 29 Enticer
Thanks! I'll have to check it out.
270Laser is offline
Old 06-28-2005 | 09:13 PM
Congrats on your purchase. I myself just bought a 1999 29 Enticer 7.4mpi 310 hp bravo 1's 25 pitch 3 blade 6/25/05. Took it out on Lake Erie never been to Ohio before but this is where i purchased the boat so i decided to take it out for a test run before trailering it home to N.Y. It ran great on the water rough at times the only concern i had was @ full throttle the boat started to lean back and forth port side to starboard side violently. I had thought maybe because of the cross wakes on the lake. But other people told me this boat doesn't like speeds over 70mph anyone know if this is true or has experienced this and know how to correct this? thank you. Paxtonsc I would like to install superchargers anyone do it to their 29?
paxtonsc is offline
Old 06-30-2005 | 09:41 PM
Hi Pax,
I had a 93 29 enticer with 454 mags for ten years. You should be running a pair of Mirage 23 3 blades, you are laboring your motors with the 25s.If you are willing to give up 1 1/2 miles a hr on top end a pair of hydromotive 4 blade 22s will improve the chime walk and is the best rough water prop for this boat with your power. If your boat came with boat leveler trim tabs, their to small and to slow. K-planes and the 22s will change the whole attitude of your boat. My name is Jeff feel free to call me Cell 516-353-9611 if I can be of further help, by the way hydraulic steering would be a good idea if you dont have it now. Take Care and good luck.
KLEEN SWEEP is offline
Old 07-02-2005 | 12:47 AM
Originally Posted by KLEEN SWEEP
Hi Pax,
Thank you Kleen Sweep i'll hold on to your phone #. I talked to Gene @ Throttles up and their top prop tech (julie ) said to go with 24pitch 4 blade Bravo. Any idea on the length of new K planes? How about hydraulic steering i'd like to install superchargers too? Thanks for your input. Paxtonsc
paxtonsc is offline
24degrees
Magnum Marine
4
06-17-2008 07:16 PM
mcourson
Powerquest
9
01-06-2008 05:00 PM
morgansrun
Powerquest
2
08-13-2007 05:23 PM
Fast Forward
Powerquest
3
07-23-2007 12:14 PM
eliminator219
12-15-2002 10:17 PM
