Mirage Plus or Hydromotive >
Old 04-14-2005 | 08:57 AM
dtsquest's Avatar
Default Re: Mirage Plus or Hydromotive
Originally Posted by BADKACHINA
If you had too much lift with the Bravo 1 I would stay away form the Hydro. The ones I tried had way more lift than a Bravo, so much that it felt like I had no control over the boat when I was on plane. It felt like my steering wasn't working.........
Thanks for the responses. I think I am going to try a stock Mirage Plus 25P, and if it runs well, I will send it out to be ladded.
dtsquest is offline
Old 04-21-2005 | 09:31 AM
dtsquest's Avatar
Well, here's a little bit of updated info. I guess the VERY long winter in Upstate NY froze my brain, because I thought I was turning 5100 RPMs. So here's my updated info from the first outting of the season....
flat calm conditions in fresh water
4900 RPMs
67 mph on gaffrig speedo (no GPS)
23P Mirage Plus with minor ding in 2 blades
I'm running a 2000 Powerquest 260SX with stock 502 MPI
My thought was to go with a 25P labbed prop, but don't know if I am getting enough RPMs? My ultimate goal is top end performance. Any suggestions other than trying them?
dtsquest is offline
Old 04-21-2005 | 10:38 AM
throttleup's Avatar
dtsquest,
You are running your motor right about were you should, for top end. So you sould run a 25P Mirage Plus Lab Finished to increase top end.
Julie
throttleup is offline
liquid asset
35
08-20-2006 08:08 PM
Frankscarab
Prop Talk
5
05-24-2006 11:51 AM
powerguy
6
08-10-2004 11:52 AM
Bo Knows
1
03-11-2002 11:15 PM
