For All You Prop Gurue's >
Old 04-21-2005 | 06:42 PM
Little Tommy's Avatar
Default For All You Prop Gurue's
Looking for some feedback on the Mercury Maximus 5 blade Propeller. I have been on the phone with the Mercury Tech guys and yes I know this is going to be a definate trial by error on my Apache.
I know these props were originally designed for ventilatated bottoms (stepped) and Cat's and also high X demesion drive set-ups.
My X demesions are relatively high on my 36' Apache and we figure that these propellers might work exteremely well overall with minimum loss of top speed if any.
My main question is are any of you guys running the 5 blade Maximus props on a non stepped V-Bottom with any success??????
I will be testing several combination of props in Florida late next week and would like some feedback before I leave.
I am presently running 30 lab finished Bravo one's.
Thanks-----LT
Little Tommy is offline
Old 04-21-2005 | 06:45 PM
PhantomChaos's Avatar
Default Re: For All You Prop Gurue's
There's a prop section now....check it out!
PhantomChaos is offline
Old 04-21-2005 | 07:11 PM
grimmy's Avatar
Cool Re: For All You Prop Gurue's
I NEED TO KNOW WHAT IS THE BEST PROP FOR MY 93 38' CIG TOP GUN? FRESH WATER, MERC. 425'S, TRS DRIVES, 190 HOURS, WANT TOP SPEED WHO DOSEN'T. GRIMMY
grimmy is offline
Old 04-22-2005 | 03:51 AM
Downtown42's Avatar
Little Tommy, call me I have a boat haul for you...Dave Brown 262-470-0333
[email protected]
Downtown42 is offline
Old 04-22-2005 | 06:42 AM
el indio's Avatar
me.i am more concerned about mid range cruise.
el indio is offline
Old 04-22-2005 | 08:15 AM
throttleup's Avatar
It is quite possible that the Maximus will work better on your boat if you have an extremely high X Dimension. This is due to the increased diameter of the Maximus. However we have found that you may still have a high % of slip for a 5b which should be around 9%-10%. After testing post some of your numbers and we can run your slip. I have found that some boats will perform better with the larger diameter but still have a very high slip %, so in esscense you are still leaving speed on the table when compared to adding a spacer to get the slip numbers at the appropriate %. I look forward to seeing your numbers!
Julie
throttleup is offline
Old 04-22-2005 | 08:43 AM
el indio's Avatar
slip can be your friend especially with bravos on a heavy boat!!!!!!!!!!!!
el indio is offline
Old 04-23-2005 | 08:45 AM
Thanks for the comments----I will document info and post when I am finished....LT
Old 04-23-2005 | 11:53 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: For All You Prop Gurue's
LT,
What's up?! You know I know your boat. We have worked together for years. I saw the Bravo 1's at Mel's place. You should send them in. They need a little help.
We have learned what the 4BL's do on your rig. We know we have to do specialty work with them to get that rig to carry. The 5BL is going to give you alot more stern lift. They will be a delite getting on plane and cruising across the big pond. But, Post 1/2 throtle your boat will have "glued to the water" issues. It's all in what your looking for. I know your more of a cruising guy.
When you get back from Florida, we could try some things. I'd like to get my hands on those 28's if you still have them.
Did you get the motor issue taken care of?
Say hi to your lovely bride.
Brett
[email protected]
bbladesprops is offline
Old 04-24-2005 | 08:23 AM
el indio's Avatar
ouch!!!!!!!!!!!!!!!!!
el indio is offline
