lab the lab >
lab the lab
lab the lab
Old 05-12-2005 | 11:57 AM
Default lab the lab
I have a 29 pitch mirage plus that was labbed - picked up 2 mph, and was bumping the limiter. I've done some small engine chnages that now get me another 200 rpm - but I can't use 'em cause I'm up on the limiter. Can you add pitch to an already labbed prop? I can't go to a higher pitch bec. 29 is highest in mirage plus and I haven't found any other three blade that gives me as good performance. Any help would be appreciated. Thanks.
bouncedcheque is offline
Old 05-12-2005 | 01:42 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: lab the lab
Wow,
Did you know the 29 Mirage is actually much higher in pitch than the 29 that is stamped on it.
That propeller in unique to the Mirage family.
Yes we can up pitch it to pull your rpm's down and hopefully gain the extra speed you want.
[email protected]
bbladesprops is offline
Old 05-12-2005 | 04:08 PM
throttleup's Avatar
Default Re: lab the lab
bouncedcheck,
Can you tell us a bit about your boat, please. What make and model, what power package, drives and gear ratio, WOT RPM and WOT MPH (gps). I am curious as to whether there might be a better prop for your application.
Julie
throttleup is offline
sidetracked
09-11-2007 01:17 AM
99fever27
Fountain
2
04-30-2006 12:44 AM
iamfaster
Prop Talk
9
04-26-2006 06:46 AM
Shooter
Baja
28
05-01-2003 10:36 AM
Quest for Speed
16
01-21-2003 11:27 PM
