difference in gear ratio's >
Old 07-06-2005 | 08:37 AM
berns29scarab's Avatar
Default difference in gear ratio's
I'm running 15x32 3 blades at 6400 rpms @ WOT with 20" sporty lowers and 1.62's. what would happen if i converted to 1.75's ? the engines are 300x's
berns29scarab is offline
Old 07-06-2005 | 09:27 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: difference in gear ratio's
Hi,
Your rpms will go up to around 6700, throttle response would improve, planing would be quicker, speed would be about the same or slightly less.
Mainly, improved throttle response.
[email protected]
bbladesprops is offline
Old 07-06-2005 | 07:34 PM
Default Re: difference in gear ratio's
thank you...a friend of mine just went the opposite way in an I/O boat. went from 1.50's to 1.35's and lost 700 rpms.
Old 07-08-2005 | 05:07 AM
spectre boy,
listen to brett
he knows all!
dan
dan lawrence is offline
Old 07-08-2005 | 12:04 PM
SCRAPMAN1's Avatar
Dan You Are A Boat Freak! Its 5 In The A.m.- Get Some Sleep Will Ya! :d :d :d
SCRAPMAN1 is offline
Old 07-08-2005 | 12:06 PM
SCRAPMAN1's Avatar
Billy
bruin_d
05-23-2008 06:57 AM
35 lightning
03-13-2008 10:52 AM
Griswald
Drives and Lower Units
3
12-08-2007 03:20 PM
cougarman
General Racing Discussion
0
08-25-2006 08:37 AM
aTX427
10
01-10-2002 10:13 AM
