Flo Hub to Soild Hub. >
Old 07-11-2005 | 08:23 AM
29KILROY's Avatar
Default Flo Hub to Soild Hub.
Hi guy's what washers, spacers do I need when going from a Bravo Flo Torque Hub to a Soild Hub Mirage? I want to try a set just for testing and want it set up right. Thanks
29KILROY is offline
Old 07-11-2005 | 03:08 PM
throttleup's Avatar
Default Re: Flo Hub to Soild Hub.
The Mercury Hub kits for the Flo Torq kits have a plastic drive sleeve and the Solid Hub Kits have a SS drive sleeve. So the only difference in the kits is the drive sleeve.
Julie
throttleup is offline
Old 07-12-2005 | 06:10 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Flo Hub to Soild Hub.
Unless you are talking about the old cast solid hub non-Plus series. Then you will need a different thrust washer.
[email protected]
bbladesprops is offline
Old 07-18-2005 | 07:18 AM
29KILROY's Avatar
BB you are right. Come to findout they were the old style needing the diff. Thrust Washer.
29KILROY is offline
overdrive75
Prop Talk
7
10-02-2007 10:11 AM
375stinger
0
12-24-2006 08:42 PM
markt111
6
04-01-2006 08:31 AM
TWC
Prop Talk
4
11-10-2005 03:59 PM
jafo272
2
08-29-2002 04:41 PM
