Looking for new props - not sure what to use >
Old 07-26-2005 | 09:30 PM
dean51267's Avatar
Default Looking for new props - not sure what to use
currently running 25p, 31' V hull, twin 454's, profile, no step boat, 330hp's, top end is about 55mph @ 4500 rpm, bravo 1's, can't get more speed than this...
Looking to increase top end, considering going to 502's this winter...
Goal is top end and better mid range, boat squats a lot, suggestions?
dean51267 is offline
Old 07-26-2005 | 10:15 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Looking for new props - not sure what to use
Slip is high.
I wouldn't spend too much time propping if your going to upgrade motors.
Rotate the props inward and upgrade the power.
[email protected]
bbladesprops is offline
Old 07-27-2005 | 08:19 AM
throttleup's Avatar
Default Re: Looking for new props - not sure what to use
What gear ratio do you have?
With 1.5 your slip is quite high at 23% if you have 1.65 gears then you have 15%. But keep in mind that the data we use to calculate your slip must be accurate. Is your speed of 55 MPH a GPS reading? Is your motor carborated? This information will better allow to assist you.
Julie
throttleup is offline
Old 07-27-2005 | 08:20 AM
throttleup's Avatar
Additionally What is the make and model of your 25P propeller?
Julie
mcprodesign
06-08-2008 07:54 PM
diggster69
Prop Talk
2
02-06-2008 07:59 PM
HOTTZU98
3
05-13-2005 07:43 AM
raiseyourdrive
09-15-2004 08:23 AM
dougB
0
05-06-2003 04:16 AM
