mirage vs. mirage plus >
Old 07-30-2005 | 08:56 AM
Default mirage vs. mirage plus
hi
what advantages does the mirage plus have over the older mirage props?
thanks
bezdikjack is offline
Old 07-31-2005 | 01:45 PM
activox's Avatar
Default Re: mirage vs. mirage plus
Since I have been doing prop research recently, what I do know is that the Plus has cupped blades, which effectively adds about +1 to the pitch - other than that no one has pointed out any other differences to me. If there are, I'd like to know too.
Aaron
activox is offline
Old 08-01-2005 | 12:45 PM
If the cup adds about an inch of pitch what would the difference be between having a 25 mirage plus and a 26 mirage?
CN24 is offline
Old 08-03-2005 | 09:13 PM
Smitty's Avatar
Mirages are only made in odd number pitches. Bravo 1's are made in even number pitches.
Smitty is offline
Old 08-11-2005 | 10:54 PM
vette131's Avatar
will a plus go faster on a heavy hull that needs a lot of bow lift like my 35 mistress?? my mirages are not plus would they help???
vette131 is offline
Old 08-12-2005 | 12:49 AM
hillbilly24's Avatar
Get ahold of Brett from bblades on this one. he seems to be the mirage exprert
hillbilly24 is offline
Old 08-15-2005 | 06:21 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: mirage vs. mirage plus
The Mirage Plus and Mirage are essentially the same propellers as far as the basic geometry. The Mirage Plus does have additional cupping to aid in reducing slip #'s. This does raise the overall pitch slightly. Not a whole inch. The Mirage Plus also has the FloTorq 2 hub assembly to allow the use on a large variety of applications. In addition the PVS system was added to help hole shot on outboard set ups.
The standard Mirage will be a faster on a boat not requiring aid in bow lift and that has great efficiency (low slip #'s). True pitch is always faster than progressive if the boat can handle it (most can't).
Bigger deeper V's tend to like the Plus series better because the trailing edge helps them to get on plane and also helps the cruise speeds.
Hope this answers some of your questions. Oh yeah, the changes took place in about 1997
[email protected]
bbladesprops is offline
Old 08-17-2005 | 12:13 AM
vette131's Avatar
thanks
vette131 is offline
Frankscarab
Prop Talk
5
05-24-2006 11:51 AM
Formula311-SR1
Prop Talk
6
08-26-2005 02:16 PM
klmken
06-18-2002 08:50 AM
Bo Knows
1
03-11-2002 11:15 PM
