5 blade v 4 blade >
5 blade v 4 blade
5 blade v 4 blade
Old 09-12-2005 | 07:23 PM
Charter/Platinum Member
Default 5 blade v 4 blade
Has anyone tried a Hydromotive 5 blade on your Cat that you usually ran a 4 blade? I am just curious if it is worth the $$$ to try a 5 blade for some extra mph...
blueamerican is offline
Old 09-12-2005 | 08:05 PM
Default Re: 5 blade v 4 blade
It could be, but as you know all boats have their own performance characteristics which determine what prop works best.
WETTE VETTE is offline
Old 09-13-2005 | 05:53 AM
In my twin cat, bravo1 30 vs. hering 31 5b., which can only judge characteristics, the hering was more efficient at 75 and above. You could really feel the transom lift which was not good for my hull until above 80. Then enough air was packed to lift the nose. At 50, had to use about double the amount of trim, and the boat had a slight porpoise, which did not have with the bravo. Surprisingly the bravo comes out much better. It is amazing how different the props are. I think you will just have to try before you know for sure.
SkiDoc is offline
Old 09-13-2005 | 01:46 PM
Nordicflame's Avatar
An HTM SR24 that I did a Whipple on this year seemed to love the change to a P5-X from a Bravo One. He said it made the whole boat feel different in a great way.
I'll have to check on details though.
Dave
Nordicflame is offline
Old 09-13-2005 | 02:06 PM
throttleup's Avatar
This will depend upon the cat. What make?
Julie
throttleup is offline
Old 09-13-2005 | 02:10 PM
Panther's Avatar
Frank's Marine Service
What will be harder on the drive? A 4 blade or 5 blade? Bravo or Hydro?
Panther is offline
Old 09-13-2005 | 02:11 PM
Hi Julie,
That was the 27P5-X we stuck on that HTM. You had added some cup to it back when we had our other Nordic.
Email me if your going to have any off season specials. I might have a set of 26s for you to look at
Dave
Old 09-14-2005 | 07:57 AM
throttleup's Avatar
I sure that we will have some sort of special...as usual, this winter. I will post it here and call you as well.
Julie
fandango
Wanted
6
05-15-2008 07:14 PM
Inspector
Prop Talk
1
07-09-2007 07:50 AM
LFarr
Prop Talk
11
08-25-2005 07:09 AM
wtpowered
Prop Talk
7
07-04-2005 02:34 AM
Intolerant1
04-08-2002 08:08 AM
