need prop help >
need prop help
need prop help
Old 09-18-2005 | 07:05 AM
mcrsr's Avatar
Default need prop help
i was wondering about hydromotive quad 4 props- right now i am using 25p mirages and am fairly happy, but naturally, always looking for better!!! anyway, i originally had merc over hub cleavers, and they didn't work great-always broke lose, boat dragged etc-these wheels look somewhat similar-how will they respond?? also, i am using 3 blade props- how much does pitch change going to a 4 blade? thanks also, originally being an outboard guy, (had 112 mph allison), how would a chopper perform?? it seems like i use quite a bit of positive trim
mcrsr is offline
Old 09-21-2005 | 05:15 PM
mcrsr's Avatar
Default Re: need prop help
i was told the mirages are best- is this true???
mcrsr is offline
Old 09-22-2005 | 11:18 AM
What boat ,power and setup do you have?
mmwalters is offline
Old 09-22-2005 | 04:13 PM
mcrsr's Avatar
32 pachanga w/ bravos, 25 mirages and 440 hp 454 engines
mcrsr is offline
Old 09-23-2005 | 09:58 AM
throttleup's Avatar
I would try to test a 24P Hydro QIV. This propeller has done well on the Panchangas.
Julie
throttleup is offline
Old 09-23-2005 | 02:28 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: need prop help
Try any and every prop you have the opportunity to try!!
We have had the best results with Mirage Plus propellers Lab Finished with extra rake on Pachangas. The 4 blade props especially Hydro Q4's have given too much stern lift.
Again, try what you can. What one person likes doesn't always work for the other guy.
[email protected]
bbladesprops is offline
Old 09-30-2005 | 09:39 PM
mcrsr's Avatar
how about choppers- if it likes bow lift why not give it some more??? any suggestions about this?? is it worth a try???
mcrsr is offline
Sick Stinger
Velocity
9
02-07-2008 11:39 AM
FlyFast
1
08-06-2004 10:22 AM
boatinbill
07-26-2002 09:58 AM
MIKEHTMSR24
07-22-2002 03:18 PM
MIKEHTMSR24
0
07-22-2002 01:40 PM
