30 spectre w OB's x dimension ? >
Old 09-30-2005 | 09:32 PM
berns29scarab's Avatar
Default 30 spectre w OB's x dimension ?
My current height is 1 9/16" above the hull. Thats prop shaft dead center. According to the manufacturer there factory set up is 1 3/8's to 1 5/8's so i'm almost dead center. What kind of speed increase can i expect by raising them a bit and how high is to high ? I'm currently spinning 62-6400 rpms 15x32 merc 3 blades @ a WOT of 105.6 ? (lite on fuel and optimum conditions)
berns29scarab is offline
Old 09-30-2005 | 11:58 PM
Ryan Beckley's Avatar
Racer
Racer
Default Re: 30 spectre w OB's x dimension ?
Bern, the most important thing in engine height is H2O pressure. The safest is to stay above 15lbs at wide open throttle.
Ryan Beckley is offline
Old 10-01-2005 | 09:19 PM
Ryan how much do you adust motor hight for different races?
mmwalters is offline
Old 10-01-2005 | 11:02 PM
Racer
Racer
In the current Doug Wright the motors have been moved once at not again. Some Guys move them up and down but we haven't. If you get them out of whack and loose H2O it cooks a motor quick.
Old 10-02-2005 | 08:14 AM
on the x's i'm seeing 5 psi at idle, and 12-18 while running depending on trim etc...
PS- Hey Ryan i put a stop pymt on that check, and am sending Dennis(DPT) down to Corpus with $40. cash
Old 10-02-2005 | 02:46 PM
Ryan I guess my question should have been, do you lower the motors for rough water races?. It sounds like you do not
Old 10-02-2005 | 06:55 PM
Racer
Racer
We do not move our motors.
Old 10-07-2005 | 08:26 AM
thanks again Ryan...
Buddy OO
01-23-2007 06:30 PM
Pete B
General Racing Discussion
12
01-20-2006 12:55 PM
berns29scarab
Spectre
1
10-03-2005 08:56 AM
berns29scarab
3
10-02-2005 08:15 AM
checkmate zt
Checkmate
14
05-01-2003 06:39 PM
