Go Back  Offshoreonly.com > Owners Forum > Spectre
30 spectre w OB's x dimension >
Old 09-30-2005 | 09:34 PM
berns29scarab's Avatar
Default 30 spectre w OB's x dimension
My current height is 1 9/16" above the hull. Thats prop shaft dead center. According to the manufacturer there factory set up is 1 3/8's to 1 5/8's so i'm almost dead center. What kind of speed increase can i expect by raising them a bit and how high is to high ? Current WOT #'s optimum conditions 105.6 @ 6400 rpms spinning 15x32 3 blade merc cleavers.
berns29scarab is offline
Old 10-03-2005 | 08:56 AM
T3's Avatar
T3
Default Re: 30 spectre w OB's x dimension
The boat will pick up speed with more height. The problem is that the motors will go into guardian mode if the water pressure is too low, the rpm too high and the sun and moon mis-aligned. This will make for a sudden loss of rpm on one side or the other, and the 300X gearcase does not freewheel so you just put the brakes on one side.
Hull or transom pick-ups will be the way to go if you seek top performance.
T3 is offline
Buddy OO
01-23-2007 06:30 PM
Pete B
General Racing Discussion
12
01-20-2006 12:55 PM
berns29scarab
Prop Talk
7
10-07-2005 08:26 AM
berns29scarab
3
10-02-2005 08:15 AM
checkmate zt
Checkmate
14
05-01-2003 06:39 PM
