lab props RPM gain >
lab props RPM gain
lab props RPM gain
Old 02-16-2006 | 02:54 PM
superboat1989's Avatar
Default lab props RPM gain
I was reading a note on the Mercury site and it stated
"Lab Finishing service to all Trophy or Tempest propellers, expect to see 150 RPM gain so typically you can move up 1" of pitch"
Why do you gain RPM with lab finishing?
superboat1989 is offline
Old 02-16-2006 | 03:36 PM
throttleup's Avatar
Default Re: lab props RPM gain
There are several contributing factors that result in the RPM gains experienced thru the lab finishing process.
It is the specific adjustments which will cause this. For instance a propeller will physically weigh less after lab finishing therefore it will produce a higher RPM as it is physically lighter. When the cup is removed this will also increase the RPM. Patterning and pitching the blades to a higher tolerance will produce higher rpm's. So when it is all said and done you will experience and increase in RPM.
Julie
throttleup is offline
Old 02-17-2006 | 09:45 AM
Thank you Julie, I did not know what was performed in the lab process. .Know it makes sense.
Old 02-17-2006 | 12:05 PM
throttleup's Avatar
Anytime superboat1989!
Julie
Boomer 880
9
07-17-2007 01:40 PM
powerguy
16
08-16-2004 08:24 PM
glassdave
19
02-16-2004 06:37 PM
puder
3
08-24-2003 10:57 PM
RON
16
04-08-2002 03:40 PM
