XR Props
Old 02-24-2006 | 05:45 PM
nordic95's Avatar
Default XR Props
Are XR drives props different then standard bravo?Or is it just a hub change?
Thanks Nordc95
nordic95 is offline
Old 02-24-2006 | 06:05 PM
throttleup's Avatar
Default Re: XR Props
It's just the hub. If the prop has a Flo Torque 2 hub system, or equivalent, it is just a matter of sliding out the standard hub and sliding in the XR (large shaft) hub.
If you have a prop with a different style hub system it may or may not be easy to change the hub from a small to a large shaft.
Matt
throttleup is offline
Old 02-24-2006 | 06:24 PM
375stinger's Avatar
i have a hydromotive 4blade, and we are adding prochargers and got new drives with larger shafts. does this prop have a removable hub or does it need to be drilled back? thanks
375stinger is offline
Old 02-24-2006 | 07:43 PM
nordic95's Avatar
So that means I can use my 3 blade Mirages as spare props as long as I change hubs.How much do hubs go for?
Thanks Nordic95
nordic95 is offline
Old 02-25-2006 | 08:45 AM
throttleup's Avatar
More likely than not it has the weld in hub. If it needs to be converted to the large hub the old hub needs to be machined out and the large hub welded in.
Matt
Old 02-25-2006 | 09:01 AM
Outdrive1's Avatar
Masher touches my
Thanks Nordic95
I think retail from Merc is about 80 bucks or so.
Outdrive1 is offline
Old 02-27-2006 | 10:51 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: XR Props
We have XR hubs for $110.
List is $142.15.
[email protected]
bbladesprops is offline
Old 02-27-2006 | 06:08 PM
throttleup's Avatar
Same here $110.65 each for a complete kit in stock.
Julie
mcprodesign
06-08-2008 07:54 PM
diggster69
Prop Talk
2
02-06-2008 07:59 PM
HOTTZU98
3
05-13-2005 07:43 AM
raiseyourdrive
09-15-2004 08:23 AM
dougB
0
05-06-2003 04:16 AM
