Speedmaster props on a Bravo 1 >
Old 03-03-2006 | 12:32 PM
Strip Poker 388's Avatar
Rob
Default Re: Speedmaster props on a Bravo 1
Originally Posted by bbladesprops
Yes there was a drive issue in Miami.
The ACE drive has its own spline configuration. It will have hub kits for the square bore (Bravo) and 26 spline log hub props. Separate part numbers and available separate. It is still to be decided whether a structure BOM's will be supplied to offer Bravo style props with the correct hub or without one completely and then require you to obtain one separately. Anticipate June before all the answers are available. I'll let you know as it unfolds.
Rob, didn't you run Labbed 30's before? I had 99.1@6000 written down at one time. The box stock props will help slightly over the Labs but I don't feel will alleviate the porpoise completely. We can do some things with those 30's to help if you want to try it. Get a base line and we can talk about it. sinking the drive is another discussion too.
Brett You keeping notes? I guess I cant lie then I really never did anymore real testing after the last time I talked to ya . I ran a set of lab 30s that had some extra work and were in bad shape ran 99.+ at 6000 2 1/2-3 foot chop ,bad day for testing and one blade was cracked , so I only made on pass.
I am also getting the B-Max new crescent lowers.Maybe that will help if not at least they will look cool
Brett like you said I need to ck everything make sure its straight and do a base line .Give you something to work from. The prob is when we go out everybody just wants to drink beer and the girls don't like chine walking
Rob
Strip Poker 388 is offline
Old 03-03-2006 | 01:48 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Speedmaster props on a Bravo 1
Sounds good, stay in touch and have a great weekend!
[email protected]
bbladesprops is offline
Old 03-06-2006 | 10:33 AM
John B's Avatar
Back to the first question, prop shafts for Bravo drives that are made to accept #6 propellers. I have a pair with the carriers that I don't need. They were custom made for a 36 Skater in 1999. If anyone is interested drop me a line.
John B
John B is offline
Brad Zastrow
Prop Talk
3
01-18-2008 10:49 PM
Dueclaws
Prop Talk
9
06-08-2006 09:10 AM
boatman747
4
03-23-2006 05:26 AM
Nykamp
Prop Talk
0
02-23-2006 04:48 AM
Perfectmix
2
06-18-2003 09:47 PM
