Crack in blade >
Crack in blade
Crack in blade
Old 04-20-2006 | 06:51 PM
Boomer 880's Avatar
Default Crack in blade
I have a 4-blade Bravo I prop with a crack along the bottom 1/3 of the blade, where it meets the hub. The crack is through the entire part of the blade.
I already have a new set of props to replace this one, but can this be welded and saved as a spare, or am I wasting time and $$ getting it fixed? I would only use it as a 'get home' prop. I did not hit anything... just was the result of a poor grind on the edge.
The boat is a 40' Hustler with twin 500s.
Boomer 880 is offline
Old 04-20-2006 | 09:24 PM
racesdad's Avatar
Default Re: Crack in blade
dont do it
racesdad is offline
Old 04-21-2006 | 09:37 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Crack in blade
As a limp home propeller ONLY, it can probably be welded.
Problem is they seem to find homes beside limp home ONLY.
[email protected]
bbladesprops is offline
fandango
Wanted
6
05-15-2008 07:14 PM
Inspector
Prop Talk
1
07-09-2007 07:50 AM
bonecrusher
03-09-2007 09:12 AM
wtpowered
Prop Talk
7
07-04-2005 02:34 AM
Uncle Toys
09-17-2002 09:30 AM
