Help in proping Fountain?????? >
Old 04-21-2006 | 09:54 AM
wstultz's Avatar
Social Distortion
Default Help in proping Fountain??????
1994 Fountain 38 fever with stock '99 Merc 502 EFI's and bravo 1's.
I need to know what props for maximum speed.
wstultz is offline
Old 04-21-2006 | 10:22 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Help in proping Fountain??????
Most likely Lab Finished Bravo 1's or Hydro Q-4's
[email protected]
bbladesprops is offline
Old 04-21-2006 | 10:27 AM
wstultz's Avatar
Social Distortion
Default Re: Help in proping Fountain??????
bblade,
What pitch and how many blades?
What are some prices I can expect?
wstultz is offline
Old 04-21-2006 | 11:32 AM
Pitch is dependent on horsepower to weight ratio.
Do you have a baseline from running any other propellers on the boat? If not, do you know an accurate wet weight? I think I know exactly what you need but, this information will solidify it.
[email protected]
Old 04-21-2006 | 02:26 PM
wstultz's Avatar
Social Distortion
I don't know a solid weight. All I know is it is a stock 38 fever and the only thing added is a westerbeak generator.
This is a friend's boat so i don't know the exact figures, sorry.
BB, what were you thinking????
wstultz is offline
Old 04-21-2006 | 02:29 PM
wstultz's Avatar
Social Distortion
I think it weighs around 8600 dry. Running 4 blade 24 pitch props and stops making power at 4800RPMs.
wstultz is offline
Old 04-21-2006 | 02:41 PM
throttleup's Avatar
The stock 502's should run about 5000 RPM at WOT for max top end. If you can provide us with any performance data it will be helpful in determining what propellers will achieve your freinds goals. THe cost of Bravo I props is $509.99 with solid hub and the cost of Hydro QIV's is the same without hubs. Additionally we will need to know the gear ratio of the drives as well. Both props will run welll on the 35', but it really depends on the driver and what he wants out of the boat.
Julie
throttleup is offline
Old 04-21-2006 | 04:58 PM
wstultz's Avatar
Social Distortion
She tops at about 5200 rpm but no more speed after 4800.
I'll try to get some more data today
Thanks for your help.
wstultz is offline
bcfountain
Prop Talk
19
05-21-2007 09:46 PM
TOMMY HIWAVE
Fountain
14
03-13-2007 12:06 PM
TOMMY HIWAVE
Prop Talk
1
03-09-2007 03:45 PM
carney
Fountain
13
05-22-2003 11:47 PM
JeffGrice
Powerquest
0
12-31-2002 09:39 AM
